Have you considered the simple fact that while your hook up connection is working your charger is not! For gods sake listen to the advice you r getting from members and check this out??? Its not rocket science.
I don't think you need to have that tone when responding to someone. Play nice for goodness sake, no need for snide remarks.Have you considered the simple fact that while your hook up connection is working your charger is not! For gods sake listen to the advice you r getting from members and check this out??? Its not rocket science.
Here's one, hopefully not too far outside your comfort zone. You may not have used a multimeter before, but it's very easy and safe to take voltage readings in 12V circuits. Any cheap multimeter will be fine for this, and you can probably pick one up for a tenner or so at any DIY store.I was merely looking (and am thankful) for some practical suggestions as to what we might try and nothing more than that…
I think Laika use a Schaudt system, if not it will probably be CBE. Both use multi stage chargers capable of providing good charging.If your MoHo battery charger is anything like mine, it is, by its design, incapable of fully charging the battery.
I assume you must have sensed my frustration at my and other members repeated attempts to explain to the OP what his issue was. Looking at posts 14, 20, 21 & 28 I think its fair to say sound advice was given. Not sure how you defined the tone from my written word but then its something I'm not going to loose any sleep over either. If anything, we now have an informative post form the O.P. and it seems all is in hand.I don't think you need to have that tone when responding to someone. Play nice for goodness sake, no need for snide remarks.
It may not be rocket science to you, but to others it may be, so be courteous and considerate when responding please!
Thanks Pausim,I think Laika use a Schaudt system, if not it will probably be CBE. Both use multi stage chargers capable of providing good charging.
I’ve had major issues with my Kreos 7009 batteries in Spain earlier this year and this forum really helped be track the problem down( thanks Lenny HB ) .With the engine running the control panel is showing 14.3v for the leisure battery - this then drops to 12v within an hour of turning off the engine and plugging the 230v back in…
Agreed a good battery monitor is a very useful gadget, ours (actually mine) is the NASA BM1.I’ve had major issues with my Kreos 7009 batteries in Spain earlier this year and this forum really helped be track the problem down( thanks Lenny HB ) .
One of the two original Gel batteries failed after three years dragging the other one down. I then bought two new 110ah Victron Gels but unluckily for me one of them proved was also proved faulty which really confused me at the time.
Victron replaced the duff battery under warranty so I’m hoping I’m back to normal now , fingers crossed.
I know it might not help you right now but can I make a suggestion that you fit a Victron Smart shunt when you get home so that you will always know what’s going on with your batteries and charging system …. best £100 I’ve spent
I would suggest to follow autorouter's advice and measure the voltage straight at the two terminals of the leisure battery. Wether bad or not, while charging it should eventually reach a voltage level well above 13.6 Volts. If it does, the charger is fine. From post #9 I understand your leisure battery monitor shows 14.3V with the engine running. At that condition, please use the multimeter (as autorouter described quite well) and measure tha leisure battery voltage straight at the battery terminals. If it measures anything below 14V the large battery fuse is blown. These are like 30Amp or 40Amp fuses.Here's one, hopefully not too far outside your comfort zone. You may not have used a multimeter before, but it's very easy and safe to take voltage readings in 12V circuits. Any cheap multimeter will be fine for this, and you can probably pick one up for a tenner or so at any DIY store.
Plug the red lead into the socket with 'V' in the label. Plug the black lead into the socket labelled 'COM'. Turn on the meter and set it to the 20V DC range. The symbol with two lines, one solid and one dotted, means DC. The symbol with a wavy twiddle means AC. Batteries and vehicle electrics are always DC, not AC.
Push the red probe onto the positive battery terminal. Push the black probe onto the negative battery terminal. You should get a reading of between 10 and 15 volts. If you get the probes the wrong way round, all that happens is a minus sign shows in front of the voltage reading.
Once you are happy doing that, you need two voltage readings at the battery terminals. One with the hookup disconnected, and one with the hookup connected.
