John Proctor
- Sep 9, 2024
- 9
- 3
- Fiat ducato benimar
The old saying .... climbing the walls ... is an understatement!
2001fiat ducato benimar europe st 6000 ... proper straight Flys through its mot over the 3 years I've had it.... love it to bits... However me and my trusted benimar are about to proper fall out I've looked and tried everything to stop this problem ...
I am reaching out for that one thing I haven't done to fix this problem.
New under bonnet starter battery cranks spot on.
A 110 ah leisure battery under both front seats that charge to 13.6 / 8 when I start the engine, checked by a multimeter and also showing the same on the control panel. All the motorhome Internal lights work and everything else as they should. So here's the problem, when I turn the engine off and test the batteries there sat at 13.6 / 8. Then turning just the habitation lights on the voltage on the control panel drops very quickly and within 4 minutes it's down to 7 and the lights have dimmed before going out. I then check directly to the batteries and they were sat at exactly what the control panel was reading...
I change the battles to two 130ah Gel batteries that I new were ok as I had took them off my garage solar system ... the same is happening with them... good charge .... lights on very quickly down to 7 lights out ...
WHAT ELSE CAN I CHECK I AM GOING OUT OF MY MIND....
HELP PLEASE
HELP PLEASE
