Laika 1999 Ecovip 4L (1 Viewer)
Jim et Lou
216
119
Sheffield
Coach built
I am new to this
Hi I need alittle information, can anyone tell me the weight of A Laika 4L. I have no paperwork to tell me anything about this. Can anyone help.
BwB
917
1,170
Suffolk UK
Resting b'twix vans
Since 1990
The manufacturers plate should be somewhere obvious at the front of the vehicle (on my Laika it's on the side of the passenger seat box).
These are maximum permissible weights.
The actual (real) weight will be specific to your own van depending on what options you've added (or taken away) and if you want to to know the weight empty or full (of water, fuel, provisions, clothes, etc.) The only way to know this is to load the van as you want it and take it to a weighbridge.
Apr 29, 2009
1,207
741
West Sussex
Burstner Nexxo T740
since 2008
Do you have the V5C? It should be on there. Our plate is on the side of the passenger (in our case driver) seat, but it could be anywhere depending on who uprated it - if indeed it has been uprated.
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Should have a GVW of around 3850kg (3.9t) if it is the 5 berth u2267. There will be a plate on the vehicle, either under the bonnet, near the seats or near the hab door.
Jim et Lou
Jim et Lou
216
119
Sheffield
Coach built
I am new to this
Thank you all for your help for your found a plate under the bonnet 5600kg
Jan 28, 2008
10,126
18,395
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
usually the plate will show 4 weights
the vehicle gross weight
the vehicle axle weights
and the gross train weight this is max with a trailer included and is always the highest figure
i assume there will be 5 weights if its tag axle
none of these will tell you what the van actually weighs
unladen weight may be on the v5
or as said its a weigh bridge job
1,207
741
West Sussex
Burstner Nexxo T740
since 2008
5600kg is the Max Train Weight on our Laika - most info I can see on line Gross Vehicle Weight is 3850kg. If you give us all the figures on the plate we will be able to tell what the Max Permissable Weight is.
Whatever the Max Weight is you should still have it weighed (if only to find out how much Wine you can carry!)
