Jim
Ringleader
No they’ve gone a little quiet. I’ll chase them on Monday and see where we are yy
Any joy with them Jim?No they’ve gone a little quiet. I’ll chase them on Monday and see where we are![]()
Their batteries are very goodI'm glad you've said that....They have just enquired about advertising here and offering a 5% Funster discount.
Excellent, Ill hold off making a change for now thenYes looks like they are going ahead very soon.
Nice work, Jim.We now have a working 10% discount code from KS Energy. FUNSTER 2022
Indeed I feel you… I spent over £3k on a pair of 200A KS cells middle of last year! Hey Ho!Now if only I'd waited a couple of months before getting my second battery.![]()
Likewise. Just ordered 2 of the low profile 120Ah to replace 2 100Ah lead acid.Can confirm code works
My 200Ah KS-Energy battery is showing an “over voltage“ fault when it is full and charged and connected to hookup. With the EBL119 set to Gel Setting
Maybe one cell gone high and activated over voltage, despite the pack voltage within limits. That’s why you need to terminate charge, or drop to a lower voltage float when full, to stop current flow into battery. Maybe few balancing cycles will even the cells a bit better.My 200Ah KS-Energy battery is showing an “over voltage“ fault when it is full and charged and connected to hookup. With the EBL119 set to Gel Setting
View attachment 569800View attachment 569801
I’ll email KS tomorrow and confirm it is OK -
it seems to be the battery BMS kicking in to protect it against over charging when full
the “fault” clears when the Hookup is removed
It is my understanding that with lithiums you should have no float voltage once fully charged.or drop to a lower voltage float when full, to stop current flow into battery
Your EBL will charge to 14.4v then hold that voltage on its absorption phase for 16 hours then drop to a 13.8v maintenance charge.My 200Ah KS-Energy battery is showing an “over voltage“ fault when it is full and charged and connected to hookup. With the EBL119 set to Gel Setting
Yes that’s right. Li when full you stop charging. However, if you can drop the float to a low voltage, does not mean you float charge. When battery full, you can have float at 13,4-13,6v and no current goes to battery, only to loads. It’s a work around and it works.It is my understanding that with lithiums you should have no float voltage once fully charged.
I don't use EHU often - I'll be ok with the B2B and solar for the majority of the time. I was on EHU, just playing with the various charging setups . I think I'll probably fit an isolator between the EBL and the Leisure Battery so if I am on EHU for a period (say at a ski resort over winter) I can be on EHU and sop the EBL from charging the lithium battery unless I want the EBL to top up / charge the lithium battery when I am on EHUYour EBL will charge to 14.4v then hold that voltage on its absorption phase for 16 hours then drop to a 13.8v maintenance charge.
IMO not good for Lithium regardless of what the distributor says. If you are going to use EHU regularly I would change the mains charger.
no - ive been too busy at work to contact them.. I'll do so over the weekendI wonder if you ever got a reply from KS, only interested because I have the same battery, not had the same issue though. It is odd that fault showed up, dispalyed voltage seems well under the cut off voltage.
both Udo at Schaudt and KS-Energy said the EBL119 Gel setting (16hr at 14.4V, float at 13.7v) was OK for the lithium Batteries (I think the issue happened in the full charge Uo 14.4v full charge phase rather than the later 13.7 float phase.It is my understanding that with lithiums you should have no float voltage once fully charged.
Both Udo & Banner told me the Banner AGM's were fine on the Gel setting, they lasted all of 18 months.both Udo at Schaudt and KS-Energy said the EBL119 Gel setting (4hr at 14.4V, 18hrs at 13.8v) was OK for the lithium Batteries (I think the issue happened in the initial 4hr 14.4v charging phase rather than the 18hr 13.8v? float phase.
any recommendations for a suitable (hopefully small size) mains charger with a lithium profile that I could put in place of the EBL?If you are going to use EHU regularly I would change the mains charger.
or something like https://www.victronenergy.com/chargers/blue-smart-ip22-charger is cheaper at £150 as it doesn't need waterproof IP rating (IP22)I think Motorhomer14 uses a similar Victron charger to alleviate the ‘EBL charging lithium’ issue
The 15 amp version is only £125 probably enough for your needs.or something like https://www.victronenergy.com/chargers/blue-smart-ip22-charger is cheaper at £150 as it doesn't need waterproof IP rating (IP22)
https://www.victronenergy.com/chargers/blue-smart-ip22-charger -
