JockandRita
- Aug 2, 2007
- 12,743
- 176,422
- N+B Flair 8000i
- Since May 05 (Ex Tuggers).
Despite searching, I am unable to find any pointers as to my problem, so hoping someone reading this may be able to help.
Until a couple of weeks ago, our Iveco rear air suspension was working a treat, as was/is our front VB air suspension. Due to a complicated problem in previous years, the Iveco system was bypassed and isolated, and inflation now operates with the left switch on the VB control shown below. The right switch operates the front air bags.
I appear to have lost 12v power to the L/H switch, ie, no power at the terminals. Using the diagram below, both the 5A and the 40A fuses (which indicate they cover the rear suspension), are both sound using a meter to check for continuity.
I was then made aware of a "pressure regulator cut off valve", which I asked Iveco Boston about when there for my MOT yesterday. Their schematic diagram from the Iveco parts website, showed a valve, but had no description for it.
This morning with the MH raised on it's levelers, I ventured underneath on my crawler board and found this. Judging by the colour of the air pipes and it's relative newness, I assume it is a VB component rather than an Iveco one.
Hoping that this was the pressure regulator cut off valve mentioned, I investigated further. The red control appears to pull out for adjustment left or right, then pushes in with a slight click, and a locking feeling to the left. Unfortunately, neither position gave any results from the cab control, so it was placed back in it's original position.
I am no further forward, with no 12v power at the switch, and the very person who will know exactly what's what, (because he fitted the system himself), is on annual leave until next Thursday at the earliest.
Until his return, if anyone has any experience or knowledge on the reason for no 12v power at the switch, I'd be grateful for their input.
Fortunately, due to the foresight of the previous owner, In an emergency, I can inflate the rear suspension manually, by means of an installed Schrader valve.
Cheers,
Jock.
Cheers,
Jock.
