I know but I managed it on ours and it shifted eventually. Just throwing ideas around in case it helps.
Now a question, what can be used to stop the red cap becoming difficult to open when I want it to?
Now my search history shows me looking up "food grade lube" on a Friday night....Food grade grease![]()
You can get a lube that doesn’t attack the bung seals and isn’t harmful to humans![]()
It's not stealing the water that's a problem, but what some drunken idiot might add to the tank.But what if someone steals your water at night?![]()
My dirty mind has lots of replies to this but I'm not sure if others would approve of my smutty responses....
It's a socket for a Whale Superfil submersible pump. You can use it to power a pump to move water from a container into your tank .... but you still have to remove the cap!............ Whats the gizmo to the right of the water fill in this image? Anything to do with water? Thanks.
If that was a concern…..I’d seriously consider where I was staying.It's not stealing the water that's a problem, but what some drunken idiot might add to the tank.![]()
Came away for a week without my key for fresh water tank. Depending on bottled water for everything. Whats the gizmo to the right of the water fill in this image? Anything to do with water? Thanks.
I lock the water to stop some scroat putting chewing gum or worse into my water tank while the vann is parkedYou can should be able fill your tank through the drain tap.
Never seen much point in a locking filler and no lock on the drain.
Same here, and I do have lockers so two separate keys.Mine isn't. But I don't have lockers.
I think I wouldMy dirty mind has lots of replies to this but I'm not sure if others would approve of my smutty responses....
Just pick the lock with nail fileCame away for a week without my key for fresh water tank. Depending on bottled water for everything. Whats the gizmo to the right of the water fill in this image? Anything to do with water? Thanks.
The first camper we bought had had that done to it ... it was a Commer Autosleeper Pop-top, one owner from new with 52,000 miles on ... it was lovely and the fresh water tank was the only thing we were never able to use on it.On a partly related note, I have heard of one owner who lent their motorhome to someone who filled up through the water filler .... with diesel.
we have all of our 'cap' keys on a single ring that stays in the van on a 'wheres the keys?' hook.Came away for a week without my key for fresh water tank. Depending on bottled water for everything. Whats the gizmo to the right of the water fill in this image? Anything to do with water? Thanks.
