funflair
And you still bought itAmazon product ASIN B005M4ZWIO.
Only downside is despite having a union jack on the box it was actually made in China
I've currently got a 200ah LifePo4 in paralel with a 220ah Gel.So it can’t be maintained on a lead acid charging profile, not according to your charging profile which is a lithium profile?
When I looked more closely it said designed and engineered in UK.And you still bought it![]()
Is anything electrical made in the UK now?And you still bought it![]()
Not a lot but it is possible to buy stuff that is made in Europe rather than ChinaIs anything electrical made in the UK now?
I’ve bought 2 x 460ah but yet to fit them so when I do I’ll let you know, I’ll prob buy another to make it 3a question for somebody using more than one I think.
I would agree with Morelo - had a couple of boats with Mastervolt kit which worked very well and was reliable (except perhaps the batteries), but config was hard work, especialy when Czone added and integration with nav instruments was required. The Victron kit we have on the current van seems equally good quality and albeit there are some quirks like the Orion B2B not reporting through VRM, it is all doing its job well.Morelo used to fit Mastervolt but they said it was too complicated for a lot of users and service centres had to reprogramme the system when hardware was changed so they moved to Buttner
We have a 600w tiny kettle but enough for two cups of tea. Most economical way to do it.I only use a 1kw kettle as well, but I m not going to criticise someone who wants a bigger one because imo the great thing about all this stuff is we have the ability to set it up to suit our individual requirements.
If you want the B2B to report to VRM, run it trough a bmv and set it as energy meter. Then connect the data cable of the bmv to the GX. No way round it, otherwise set the system as HAS DC and you will see the B2B input as negative values in the DC tile.I would agree with Morelo - had a couple of boats with Mastervolt kit which worked very well and was reliable (except perhaps the batteries), but config was hard work, especialy when Czone added and integration with nav instruments was required. The Victron kit we have on the current van seems equally good quality and albeit there are some quirks like the Orion B2B not reporting through VRM, it is all doing its job well.
You have lost me with that reply. It can be maintained on a lead acid charging profile and that is what I have with my solar panels and the Sargent charger.So it can’t be maintained on a lead acid charging profile, not according to your charging profile which is a lithium profile?
An entry for the most acronyms in a single post perhaps.If you want the B2B to report to VRM, run it trough a bmv and set it as energy meter. Then connect the data cable of the bmv to the GX. No way round it, otherwise set the system as HAS DC and you will see the B2B input as negative values in the DC tile.
Interesting, I am having the same multiplus fitted later this month by the good folk at Van Bitz. I have elected for a single 300 ah battery (Sterling) due to space in the locker and supply availability. The battery is specced at 300 amp continuous discharge so I thought it would be fine for my purposes. I don't anticipate plugging anything in that would draw more than 150 amps (1800 Watts), so thought I had plenty buffer to allow for peaks and not being too anal about what was switched on at anyone time. I never considered that the BMS might be a weak point. Should I be concerned?Two batteries Lenny it’s a no brainer, you will put less stress on each bms. These bmses are mosfet based swich, means all current passes trough the board. Less stress and less heat longer and more reliable life. Always spec double for what you expect to be peak power.
The BMS will limit current. If you ask too much, it'll shut down. It shouldn't cause a safety issue.Interesting, I am having the same multiplus fitted later this month by the good folk at Van Bitz. I have elected for a single 300 ah battery (Sterling) due to space in the locker and supply availability. The battery is specced at 300 amp continuous discharge so I thought it would be fine for my purposes. I don't anticipate plugging anything in that would draw more than 150 amps (1800 Watts), so thought I had plenty buffer to allow for peaks and not being too anal about what was switched on at anyone time. I never considered that the BMS might be a weak point. Should I be concerned?
Sorry, but I was in a rush at the time, what I was trying to say, lithium batteries can't be truly maintained on a lead acid charging profile, they can be charged to an extent, but to be properly maintained, it needs a lithium profile, to fully benefit, also they can be fast charged with like 50Ah to 60Ah which a lead acid charging profile can not do, which means you would be spending a lot of money for Lithium battery, and gaining on the weight issue only.You have lost me with that reply. It can be maintained on a lead acid charging profile and that is what I have with my solar panels and the Sargent charger.
I would like to agree with you, but I can't.If you want the B2B to report to VRM, run it trough a bmv and set it as energy meter. Then connect the data cable of the bmv to the GX. No way round it, otherwise set the system as HAS DC and you will see the B2B input as negative values in the DC tile.
Why should it be a weak point? It’s safety device rated at its given amps, to protect the battery and installation. Your setup will be fine.Interesting, I am having the same multiplus fitted later this month by the good folk at Van Bitz. I have elected for a single 300 ah battery (Sterling) due to space in the locker and supply availability. The battery is specced at 300 amp continuous discharge so I thought it would be fine for my purposes. I don't anticipate plugging anything in that would draw more than 150 amps (1800 Watts), so thought I had plenty buffer to allow for peaks and not being too anal about what was switched on at anyone time. I never considered that the BMS might be a weak point. Should I be concerned?
I don’t think you quite understood my explanation, it take two bmv’s To achieve what I said. One left as it is, and the second set as energy meter. This is how VICTRON recommends going about it, and many took that path for their needs.I would like to agree with you, but I can't.
Currently, the VRM system doesn't really understand the BMV when it is set as an Energy Meter. In that mode, the BMV is really just a display of the instanteous power and doesn't log anything of use. What you need to do is leave the BMV as an SOC Battery Monitor. The VRM system will then both show the point-in-time data AND it will log cumulative data as well.
I have a BMV-712 in series with my non-Victron 60A B2B. It is set in the default way (SOC Monitor) but I have the battery capacity set to around 2000Ah and the "full thresholds" to some figures that will never be attained. This way it will keep logging current from the B2B and you can see how much it is contributing when analysing the VRM data downloads.
FWIW, I have my AMT12-2 Battery Maintainer on the same circuit so when I am not getting any power from the B2B, the same BMV is able to tell me how much trickle charge I am sending the Starter Battery when that is active.
Yes, I understood fully.I don’t think you quite understood my explanation, it take two bmv’s To achieve what I said. One left as it is, and the second set as energy meter. This is how VICTRON recommends going about it, and many took that path for their needs.
Yes. And for Motorhomes.Is anything electrical made in the UK now?
I love Victron kit, and the Victron Community is a very good resource. But it is not infallible and their kit is not infallible either.No I haven’t tried it, I came across at victron community about it, where one of the staff, (GUY) said that’s one method supported by them. In the boat use, this is more adopted than on wheels. And with the new GUI I think there’s more options to skin a kat now, then before.
package manager? battery aggregator? please tell me moreI haven’t test it as I don’t have a need. Lots of things have been added and adjusted in the last development. Under beta 3.20 you have bags of features. The dc meter was requested long time ago and victron responded with changes. Lots of work was added from voluntary support by clever and kind ppl either via Git hub and Betts reporting on the victron community.
What I see in package manager is battery aggregator was not there before, in display under GUI you got lots of new power settings, many aimed for boats, but loads can be universally used.
I’m particularly interested and monitor the modification space, along with beta reports, some bits are above me, but I’m there to learn.
Like others Martin, we love our little low watt kettle, ours being 830w. It holds enough for 4 x cups.I don't see many alternatives if we want a cup of tea![]()
for a 12V system, just multiply the AC amps by 20. so 2A on AC = 40A on DC. It will maybe be a little less but with voltage drop due to sag and inverter inefficiencies, x20 will be close enough.I forget how to do the 240v/Amps calculation with 12v.
Thanks in advance.
Jock.![]()
Hi JockLike others Martin, we love our little low watt kettle, ours being 830w. It holds enough for 4 x cups.
Staying on the Lithium theme, we have 4 x 90A SLA batteries, of which we can only safely use up to 50%, ie, 180A.
Our highest consumer of power would be the 2000w induction hob, which is never used above the 1000w setting.
With only running the Alde heating on gas, I think that ideally, 2 x 150A Lithiums would serve our needs with power to spare, ie, possibly never ever taking them down to 10%.
So, A.... what amperage would a 2000w induction hob take out of the Lithiums, and B.... would the BMS (or both jointly), be able to cope, without closing the batteries down? I forget how to do the 240v/Amps calculation with 12v.
Thanks in advance.
Jock.![]()
Thought I would just switch back to Energy Monitor mode to see if VRM has changed and logs data .... This mode is not available on the BMV-700 that I now have on the B2B line.PS. I said initially I had a BMV-712 in series with the B2B. I forgot I did some jiggling around and I actually have a BMV-700 there now (I swapped it over with the BMV-700 I had on the LiFePO4 bank) but I don't think that will make any difference to the way the data is logged.
Thanks both.but yes x20 is close enough, W=VxA so therefore A=W/V.
