Is this an12v external water pump connection ? (1 Viewer)
MisterB
6,606
15,130
Adria 670 SLT
This connection is fitted next to the water filling point, so I assume it's for operating an external pump if using a container (aqua roll type) for topping up water.
I tried testing it both with the auxillary power setting on and off, but got no reading both times - can anyone suggest why? Is it likely to be activated by some sort of float switch in the water tank?
It's on an Adria and looks to have been installed during the build. I can't find anything in the handbook that mentions it.
I'm thinking of using it for a folding solar panel connection into the Motorhome ratte than making another opening.
Dec 2, 2019
4,542
10,128
South Lincolnshire
Rapido 7065+
Broken most bits now
Nov 13, 2011
1,554
5,130
30 years
It is a 12v supply socket, which can be used to power an external transfer pump. For instance to transfer water from an Aquarol to the vehicle tank. I am sure the last time this was asked, someone found a plug at reasonable money, so worth searching for.
Geoff
Feb 27, 2011
15,133
79,934
Jim can tell you all about these :p :D
M
MisterB
6,606
15,130
Adria 670 SLT
Thanks. It seems to make more sense to remove it and utilise it for the folding solar panel. I will consider enlarging the hole and fitting the external power socket I've just bought and adding some sort of connector for the solar connections
I just need a few days to weigh up all my options before I start. It's not an urgent job and will prob be started next week.
M
MisterB
6,606
15,130
Adria 670 SLT
Did you buy your Adria new?
If so, you should have received a pump with it.
(we got one with ours)
No we didn't, but thanks for the post. I did assume it was original just looking at the location and 'age wear' of the cover, so thanks for confirming.
How is the pump activated as the cables don't seem to be live?
Oct 8, 2014
1,707
3,288
Wiltshire
Autotrail Excel 600B
Previous VW Camper + Caravan
As already said, it's for a Whale pump. On our Autotrail it's only live when the Shureflo pump is switched on.
Cal54
3,867
64,332
Southport, UK
Leisuredrive Renoir
Since 1996
I have the same on my PVC and I’ve lost the plug end off my submersible pump😟. Having seen the price of a replacement I haven’t bothered - I just stick the wires in the socket and hold it in!! Not ideal I agree but it is very rarely used, as a hose is my usual method of filling.
M
MisterB
6,606
15,130
Adria 670 SLT
Thanks for the replies. I may even leave the connection for future 'buyers' - in about ten years lol.
For those without the plug end - here's an alternative that I have bought to see if it would be suitable for my external folding solar panel connection BUT it might also be an option for 'The Plugless' amongst us ...
M
MisterB
6,606
15,130
Adria 670 SLT
i know i am revisiting (one of) my old posting - but does anyone know if this plug will fit - it looks very similar - or has anyne sourced a plug that does fit?
Oct 8, 2014
1,707
3,288
Wiltshire
It doesn't say in the listing if the pins are two different diameters, as in the Whale one. The £22 postage would stop me. I'm considering trying to make my own plug, either as a 3D print, or else by building up the shape with a hot glue gun .
43,704
52,339
It could look like a pair of trainers as long as the pins are in the correct place.
But it will take an age to fill a 70 liter tank.
M
MisterB
6,606
15,130
Adria 670 SLT
Its not my intention to fill the tank, but when we're at a rally and need to add some water then it might be an option. I've seen lots of people using watering cans to add a couple of gallons and did consider a collapsible watering can, but as we already have a collapsible bucket I wondered if I could make use of it.
M
MisterB
6,606
15,130
Adria 670 SLT
My thoughts were that if they're a chandlery item, would they be available in the UK ...
JockandRita
11,783
156,812
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
It would be quicker (and cheaper) Dave, using a piece of plumbers right angled pipe to fit in the water tank filler neck, and pouring the bucket full in. ;) As an example............
Cheers,
Jock. ;)
M
MisterB
6,606
15,130
Adria 670 SLT
Cheers,
Jock. ;)
Or just buying or even 3D printing my own funnel! I'm sure others have already done it ..... Though I did find a collapsible bucket with watering can connections ....
