I second thatI’ve cut at the top for the windows. The bottom bit is more vulnerable to dent in. I would cut and move it relocate. I also would add ply ribs to stiffen up the surrounding of the new opening.
This is the off side rear of a Peugeot boxer. I'd like to put the fridge here but would need to remove this rib to fit the fridge vents. Is that acceptable?
Nick
You can remove it if needed. As mitzimad said above, it's just there to deaden sound, it's not structural.
Just need to trim through the small spot welds top and bottom, then it should come out without much effort at all.
Totally understand what you mean, but I wasn't guessing, I was going by the official converters book.I'm sorry to have to disagree with you, but in my opinion, with the opposite side already weakened by the sliding door, (presuming there IS a sliding door) as there is no chassis, to remove that strut, unnecessarily, would weaken that centre section considerably in an accident causing a roll-over.
I just cut the steel panel surface & removed that leaving the rib in place.This is the off side rear of a Peugeot boxer. I'd like to put the fridge here but would need to remove this rib to fit the fridge vents. Is that acceptable?
Nick
Neither was i as i also checked facts before commenting i checked this out when i did my self build using the same document as wisselTotally understand what you mean, but I wasn't guessing, I was going by the official converters book.
I've edited my post to say I'll send a copy to the OP
You never know ... the spare rib might turn into Eve ....Simply remove the rib It won’t cause any problems
I wondered why my wife counts my ribs every night as we get into bed!You never know ... the spare rib might turn into Eve ....
so the fiat convertors hand book is wrong ?While I appreciate Wissel, and others, conversion experience, one of the reasons I hold/held a full HGV, PSV, Motorbike etc. was so that in the 70's I could be a Freelance Driver and turn my hand to anything on the UK roads.
This experience got me demonstration and test-driving work from some of the large vehicle manufacturers both here and abroad, Leyland, Scania, Daf etc. and knowing how to sign a 'secrets document'.
The only reason I mention this is, during that time I realised, no manufacturer would put on extra metal or paint that was not, absolutely, necessary!
As I was told many times when I asked for something extra, "£1 saved on a manufacturing run of 1000's equals a lot of wages".
Because of this, I still do not believe that that strut is unimportant or is there just to stop 'drumming' especially if, like so many converters, you are going to cut more struts in the roof to facilitate skylights.
I think this, unnecessarily, weakens the integral structure of the vehicles. How much, I don't know?
It's your vehicle and your choice but if it were me, I would revise my plans.
Good Luck, I'll say no more!
Dodgy. We avoided it as it appears fairly structural to vans integrity. Our vent is just below and I created a flow channel down to the vent with a pair of silent pc fans. The folw of warm air out sucks the cold in from lower vent. Works a treat. We get ice in Greece at 35c.This is the off side rear of a Peugeot boxer. I'd like to put the fridge here but would need to remove this rib to fit the fridge vents. Is that acceptable?
Nick
If you look at the bottom of the rib section you can clearly see it isn't attached to anything of substance so definitely not structural.This is the off side rear of a Peugeot boxer. I'd like to put the fridge here but would need to remove this rib to fit the fridge vents. Is that acceptable?
Nick
