So that's the end of a Mr Whippy on the prom.It's now potentially an offence to run an engine while stationary -
Shouldn’t that sort of thing happen in private?So that's the end of a Mr Whippy on the prom.![]()
Never !Of course I could be talking out of my exhaust pipe.
I do it at home as the van is permanently plugged in & if I am adding bits/working on it at times it is necessary to start it. Sometimes I need to run it up the ramps but I never bother unhooking.I don't understand why you would want to do it. It's now potentially an offence to run an engine while stationary - the emissions from idling engines are greater than when the vehicle is moving.
I would ask why would you want to?Why not?
With my Hobby Van, I must not run the engine with the EHU hooked up. If I do it blows the fuse in the Sargent charger. Then its a right pain to put in a new one. Drivers seat off to change it.I was under the impression that if you run the engine whilst Hooked up...It can have a undesirable effect on the charger? Pappajohn...Do most motorhomes have that link you mention?
I have done it to be honest , but been told off by the dealer when mentioning it? Dont know why ...even now? Interested to know the correct way..
That sounds like there is another issue. What fuse do you replace? a mains fuse or a 12 volt fuse?With my Hobby Van, I must not run the engine with the EHU hooked up. If I do it blows the fuse in the Sargent charger. Then its a right pain to put in a new one. Drivers seat off to change it.
Why what?Im going to add to the growing voice shouting 'why' ?
As asked elsewhere, why do you want to run it.?
Our engine hasn't run since September. And probably won't run it until March. Same every year and it's fine ?I do, because in winter, the engine might not like staying too long without a now and then start and run. I do it every 2 or 3 days at the moment as it's quite cold here, but it stays in front of my house, as I also run electric heater during the day and before you ask, no , not during the night, as I've had already rats in and I know they love comfy mohos! During the day I dry it up. I leave a little square of sponge on the table to see if the damp has been imortant during the night.
Brighton Corporation's 20 or so gritters last for many years and are only used for a few weeks a year. They're just parked up outdoors on chargers until needed.Our engine hasn't run since September. And probably won't run it until March. Same every year and it's fine ?
That’s to stop people driving off plugged in
I can't see any harm being done by running the engine whilst on EHU,
Ours does that until I move the gear selector up to the neutral position.If I run ours with Comfortmatic on idle on EHU or not in neutral a continuous loud warning sounds, drives you mad.
Hi the Sargent charging system has an inbuilt fuse which will blow if you start the engine on hook up. Seems logical why would you want to start your engine with the EHU in place. The book says do not do it so I do not. Simples.That sounds like there is another issue. What fuse do you replace? a mains fuse or a 12 volt fuse?
Your AC side should have nothing to do with your DC side except battery charging, and as has been explained, charging a battery from two sources isn't an issue, Solar when on hook up for example of a Fuel Cell and Solar and Alternator when driving
