Inverter size (10 Viewers)
Aug 21, 2008
707
1,408
Lincolnshire, UK
Autosleeper Symbol
Since our motorhome we have managed with a 300watt inverter but I am finding it more and more difficult to walk anywhere when away in the camper,I’ve now bought a power chair to travel with so bring a numpty I hav’nt got a clue which sized inverter I need and as I’l probably go to the Lincoln show if any one can help with the size I need it would be greatly appreciated.The chair is a 24volt 12 amp lithium battery and below is a picture of the charger.
May 7, 2016
7,941
13,509
West Sussex
Malibu Van 640 LE K
Since 2003
1.2A at 230V is 276Watts so you would be getting close to your 300Watts. Is your inverter a pure sine wave one? If not it might worth getting one that is and has a little more capacity.
Alan
Aug 21, 2008
707
1,408
Lincolnshire, UK
Autosleeper Symbol
Thanks the one I’ve got is’nt a pure sine wave,I’l see what’s available at the show.the one I’ve got is about 18years old and over the years it’s been hardwired to batteries clipped and it’s now just on a cigarette lighter plug for charging phones
542
544
Cathargo
It may have a bearing on the inverter, but what leisure batteries do you have?
230
410
Etrusco CV540 DB
You need to be aware that a more powerful inverter connected to 12V via a standard cigarette lighter type socket may blow the fuse supplying it if used to its full capacity for multiple chargers, and ideally should be permanently wired to the leisure batteries via heavier cables and a suitable fuse.
If you decided to do this it might be worth going for a 1000W inverter as you could also use that for an electric travel kettle. We find that much quicker and more convenient than boiling a kettle on the gas ring.
Alan
Aug 21, 2008
707
1,408
Lincolnshire, UK
Autosleeper Symbol
We’re on our way back to Lincolnshire today so will have a look at Lincoln motorhome show and see if anyone’s fitting inverters the 1000 watt one does seem the better option,We have to be a bit frugal with power usage as our fridge is Compressor and the van is only fitted with the equipment it came with,100 amp solar 2o amp bat to bat and 10 amp mppt controller😎
542
544
Cathargo
Inverters can be very useful, and it is nice to be able to use normal stuff from home.
The problem with them is whatever you use, has to be replenished, so the system would ideally be balanced.
100w Solar and 20amp b2b isn't a great deal, so I wouldn't go too mad on inverter size!
Of course you can fit a big inverter, intending not to use the full capacity, but at some stage you will! Also the bigger the inverter the more it will use on standby if you leave it on.
If you look at Victron, bare in mind they use VA rather than watts to rate their output - Whilst its the most accurate method you should consider that 500VA will be roughly about 400w - I wont go into why there's a difference but it's due to the "power factor" of the device being used.
We have Victron kit, the inverter is good in that it is quite efficient, and can be set to have a very low standby power consumption, and the Pure Sine wave is apparently pretty accurate.
Good at the show!
Alan
Aug 21, 2008
707
1,408
Lincolnshire, UK
Autosleeper Symbol
Good at the show!
We very rarely go on hookup so I’l probably have more solar and a bigger b to b fitted in the near future.
230
410
Etrusco CV540 DB
That being the case, it may be worth while going for a bigger inverter that will run a kettle/toaster. Stick to a sensible size like 1000-1500W and that will cover most stuff.
Yes agreed. We find our air fryer a bit of a game changer but that takes 1500W so we can only use it on EHU at the moment. I would need to upgrade our 1000W Renogy invertor to the 2000W version to use the air fryer off grid.
7,941
13,509
West Sussex
Malibu Van 640 LE K
Since 2003
You will use approx 26 amps @ 12 volt d.c. to produce 1 amp @ 240 volt a.c. Allowing for voltage drop and inverter efficiency.
Useful calculation though I would be a tad more optimistic than that using the figures for my Victron Phoenix 12/500 and lithium batteries.
1A x 230V = 230W
230W / 12.8V (Lithium voltage) = 18A (approx.)
18 / 9 x 10 (90% efficiency) = 20 A
The higher nominal voltage of lithium batteries (12.8V compared to lead acid’s 12V) improves the equations. In practice both battery types should operate above their nominal voltage levels through most of their useable range.
Having done this calculation it leaves me wondering whether battery Ah are as useful a comparison of battery capacity as I had thought they were. 100Ah at a lithium nominal voltage of 12.8V = 1,280 Wh whereas 100Ah at a nominal voltage of 12V = 1200Wh. This means the lithium battery has a 6% larger capacity than its lead acid equivalent. Am I missing something?
20,129
33,536
1A x 230V = 230W
Watts and watt/hr are a far more reliable indicator of capacity but we have all got hung up on amps and amp/hr, when it's a 24v battery the amps makes even less sense ;)
2,112
2,669
1A x 230V = 230W
Optimism is great reality is often disappointing. If you expect less and get more great
MisterB
6,784
15,597
Adria 670 SLT
i would bite the bullet and go for the 3000w version and 'tempt' Alan to buy your 1000w inverter .... :unsure::unsure:
230
410
Etrusco CV540 DB
That's a thought I suppose! My 1000W won't be available until we get back from the current trip in about 2 weeks, but let me know if you would be interested Alan.
I might have to go for the 2000W model as that would be a straight swap spacewise. I think the 3000W model is bigger and may not fit In the space available.
MisterB
6,784
15,597
Adria 670 SLT
and of course cable sizes might need to be increased, but you might have to do that anyway?
just checked and the 3000w is 40mm longer, same height and width ....
2,112
2,669
We have the Victron 12/2000/80-30 inverter charger, we run a Tassimo, 1000w induction hob and at times our Dometic Freshjet 2200 A/C we are limited in practicalities to carry more the 2 x 100 ampTransporter Lithium
