Inverter problem
Hymer B680
My inverter is making a continuous beeping and I’m not getting power from it. I read that it’s probably because the leisure battery is low however the control panel says it’s fine. I’m off grid at the moment but will be hooked up tomorrow, hopefully all will be well again. Is it just me or does anyone else find problems every few days? We’re in Spain for 90 days and it’s been one thing after another.
I think with a laptop and phones etc you will find a few 12V sockets very useful, much more use than a big inverter. Also the sockets will take USB adapters for the phone/satnav etc. It's not so difficult to fit some 12 sockets.
I would like more info on how to fit 12v sockets please.
I've fitted a few of these..
Takes a couple of weeks to arrive but much cheaper than UK sellers.
Just drill a 30mm hole and clamp them in. Then wire it back to the leisure battery via a 10 amp fuse or you can fit an additional mini fuse box.
£1.88 12%OFF | 12V Cigarette Lighter Socket Waterproof Plug Car Charger 24V Motorcycle Marine Accessory Power Cigar Lighter Socket
do a search for CBE sockets, they look so much more professional as if they were factory fitted. you can get a variety of sockets, switches and surrounds. the surround help to cover up any minor mistakes when cutting out.
its a simple job to wire them up - there is a positive and negative wire to each socket - its a bit more difficult to fit them into existing interior woodwork, but with good planning re where the cables will 'run' and where the outlet is best placed, it becomes easier. use the correct size cable, i usually use 10A cable.
i use a drill AND a multitool with small blade to achieve a neat hole. put some masking tape over the area to be cut out and draw the outline of the cut onto the masking tape and cut through the masking tape. it helps to prevent the blade from slipping
just make sure you have checked there are no wires or pipes running where you are cutting.
Hi Lenny,
As you realize I'm new at this game. You were right batteries are goosed. I'm in the process of buying some more 2 @ 110 ha ? When I bought the van the owner told me that the only reason he had an inverter was for his wife's hair drier so I'm now wondering what is the point of having an inverter if she can't use it or de we need a much less powerful hair drier?. If I may ask one more thing, because my sat tv does not work here in Spain I have been using my laptop to watch tv and when I'm not on hook up I have plugged it into the inverter, would that have damaged the batteries? also when travelling between sites I have been charging the laptop thro the inverter Is that ok?.
My wife's hairdryer is only 700w. Think about a lower capacity one. Also if you are changing batteries think about Lithium. I would use an inverter with Lead acid batteries they wont last 5 mins
If you're going to be fitting more than one 12V socket, a good place to start is to install a fusebox. Some fuseboxes are only for the positive wires, but this one is good because you can wire the negatives as well as the positives.
Connect the leisure battery positive and negative to the power terminals of the fusebox. Use at least 10mm2 wire, and put a big fuse, 30A to 50A, in the positive wire near the leisure battery. A fuse holder like this is easy to install:
It takes fuses like this:
Then wire each 12V socket positive to a fuse terminal, and connect a negative from the negative common connection on the fusebox. Insert a fuse -10A or 15A - and you're ready to go.
Reverse polarity has nothing to do with it.
The hairdryer is a much higher load so you will get a bigger volt drop, sounds like your batteries are shot.
What is the wattage of the hairdryer?
What type of batteries and how big?
My OH knows a thing or two about electrics (until recently he looked after Broadcast TV OB trucks) and he said the same thing.
We all started somewhere learning about what seems obvious to us now. Surely we must encourage those starting out with this way of travelling.
As mentioned above, there are a few low wattage hairdryers if really needed.
I would recommend a Lithium Iron battery from Super B. Mine is about 150ah which I’ve used for about 8 years, coupled to about 350watts of 4 solar panels. A 1500watt Dometic sine wave inverter gives me enough juice for a Nespresso and 900watt Nutribullet each morning.
We all have different needs and the wattage of appliances must be worked out with the amps before investing In a costly off-grid system.
Proba ly is low voltage, your panel will show the voltage at the battery. The voltage at the inverter will be lower due to volt drop on the cables, may well have been fitted with undersized cables.
What are you running with the inverter watts wize?
What size and type of battery bank?
Hi Lenny as previously stated I have just had fitted 2 x 130 ah leisure batteries, yesterday the above door control said 13.7 volts and 100% AH, I was on hook up the whole time, Today I have just moved sites and the readings are now 13.7 volts and 7% HA, I've not been using the the 12v system at all so can't understand these readings, any ideas please ?. Jack
It's difficult to tell what's wrong without further measurements, but if the voltage is really 13.7V then it's unlikely the state of charge is really 7%. Maybe the Ah gauge is faulty, or it's not been wired in properly so it can't measure all the amps flows. More information on the system would help. What is the make/model of the distribution/fusebox and the control panel? A photo of them might help, maybe someone could recognise them.
The vehicle is an Autotrai
l Comanche, The control panel is a Sargent EC 500.
Sargent EC 500
The vehicle is an Autotrail Comanche, the control panel is a Sargent EC 500 I'm currently on HU and the AH has risen to 9%
The EC500 'Power Supply Unit' has mains protection breakers, 12V fuses, and wiring for distribution. The control panel is the small panel with an LCD display and some buttons and LEDs, probably above the door. If it's the EC370 panel. it doesn't have an Ah display, so it might be a later model.
Edit: From your picture just posted I can see it's not an EC370 control panel. I'd say there's something wrong with the Ah measurement - either there's a fault in the measurement unit, or the wiring isn't channelling all the charging amps through the shunt. Or maybe it needs recalibrating/resetting to tell it the new battery capacity, but I don't know how to do that.
Yep, first off use the guide to re-calibrate the AH.
I'm very gratefull for this link however where it says set the battery size I don't know what to do as I have two x 130 Ah batteries so do I put 130HA or 260 HA ?
260 Ah as that's the available capacity, it won't be as high as that but that will do as a rough guide
