Interior Seat Modification (1 Viewer)
Nov 18, 2016
748
1,137
Worcestershire
Burstner Elegance
Hi, can anyone recommend a company that does seat modifications to an Autotrail Chieftain? My friend has 2 straight bench type seats running opposite in his lounge but wants to change one of them to a "return" type set up so he can take seatbelted passengers. Autotrail say they don't offer that type of service! Seems a bit strange cos they made the exact same model with the "return" type seats. Hey ho.
Minxy
32,726
66,826
E Yorks
Carthago Compactline
Unfortunately you'll be very unlikely to find anyone willing to change your friend's MH to carry additional passengers, if it was just to change the seating arrangement it wouldn't be an issue, but once you get to wanting extra seatbelts etc fitting it is a much more complicated job needing strengthening steel framework etc. I fear your friend's only option would be to change to one with the extra passenger seats already fitted (ie by Autotrail originally).
A
Nov 18, 2016
748
1,137
Worcestershire
Burstner Elegance
Yeah, I know where you're coming from BUT, seeing as Autotrail made the exact same model with the return type seating as an option surely the seatbelt mounting points (apart from the one at the top) should already be there?
Nov 5, 2013
3,143
98,672
Shropshire
Carthago chic e-line
Since 2013
The bottom seatbelts will be mounted to a large metal frame that sits under the seat and this in turn is bolted through the floor to the chassis.
I'm sure somewhere on the AT site it'll tell you how much the extra weight is!
just had a look 25Kg for the half dinette option with two seat belts.
Alistair33
1,079
3,258
North Yorkshire
Hymer
None
Not sure of the make or where you can buy but there is a fold down seast available as an after market extra that has an integral seat belt. They are sometimes fitted in under seat lockers, I guess that they need to be fixed to the chassis
A
Nov 18, 2016
748
1,137
Worcestershire
Burstner Elegance
Thanks. Don't think he's worried about the extra weight. He just wants to avoid his daughter and grandchildren having to follow in a car if they go away somewhere. Ta.
R
Robert Clark
I'd speak to your insurance company and ask them if they would accept a modification like this.
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
You have to wonder why he bought a van that wasn't suitable..
But .. Having said that. if he doesn't want to get a more suitable van then he might try someone like A&E leisure at Northwick.
Badknee
7,421
416,565
notloB
Vantage Neo
Living the dream.
Our Hobby has two rear passenger seats with three point belts fitted. They have a massive steel frame that the builders of the Forth road bridge must have designed but both my V5 and insurance docs stipulate two seater not four.(n)
celticmini
106
113
wales
Bailey 740
Another option, which is one i have toyed with, is replace passenger seat with a bench seat from a ducato or boxer van. Bolt holes in floor are the same, the seat incorporates an additional seat belt.
I have been told but not tried it, it takes less then an hour to swap seats, i have considered doing this as and when needed.
It is easy, i am told, to amend v5, as ducato or boxers are either 2 or 3 seaters. Similar with insurance.
Bench seats are cheap. About £100, even reupholstering would not cost much more than £200 more. Much cheaper then the rear seat conversion if it could be done!
Just an idea!
A
Nov 18, 2016
748
1,137
Worcestershire
Burstner Elegance
Just an idea!
That's a good idea!
Gellyneck
9,459
18,947
Scotland
More than toes wet now!
This is what the travel seat option seatbelt frame on a Frontier Savannah looks like.
Guess it will be the same as that fitted to the Chieftain.
It extends all the way up behind the seat back cushions.
The timber bulkhead behind the seats is different from the twin parallel bench option and would also need to be installed as the seatbelt frame is bolted to this. As the kitchen worktop \ sink \ floor cabinet \ high level cupboards \ etc are attached to the other side this is probably the reason why there is no retrofit option from Auto-trail.
A
Nov 18, 2016
748
1,137
Worcestershire
Burstner Elegance
Brilliant! Thanks. Those pictures speak a thousand words. I'm guessing the bolts in the floor go direct into the chassis. Should be a straight forward job with the right bits and a bit of carpentry.
Gellyneck
9,459
18,947
Scotland
Had a look underneath but can't (easily) see the tips of the bolts and nuts. They definitely do not go directly into the chassis as the floor is raised up off of this with service pipework, etc running between the floor and chassis members.
Would guess the bolts go through into the support brackets \ channels used to raise the floor.
As the traveling seat is an option sold as a factory fit option at build time would they sell you the parts for self-fitting? The option was around £800-900 on a 2013 Frontier model (which includes the Chieftain).
You'd also, probably, need to consider the implications of changes to the V5 and if this is achievable with a self-fitted change to specification.
A
Nov 18, 2016
748
1,137
Worcestershire
Burstner Elegance
Brilliant thanks. I'll let my mate know.
May 31, 2015
11,799
45,066
Cornwall
Ducato PVC
Getting Better
Both correct.... he would have to change the V5 to a four seater for the insurance to be valid... I wouldn't want my kids in anything but purposely/legal seats....
Feb 19, 2022
62
15
Anywhere
AUTO-TRAIL 740S
I'm coming late to this thread. My wish is different in that I would like to have a rear corner "double" bed removed and replaced with an L-shaped seating arrangement easily converted to a bed using the table that would go there.
This would reduce the under-bed storage but I accept that.
The van is an Auto-trail. Could they do this?
TheBig1
17,666
43,560
if you are not trying to fit travel seats into it, any carpenter could do a decent job of the conversion. There are a couple of companies that can make the cushions and upholstery to fit the new base
