Lithium batteries are like lead-acid batteries in many ways but they are totally different in many ways too.
One big difference is float charging. Lead-acid batteries deteriorate if they are left in anything less than 100% charge for any length of time. To avoid this, they are float charged, ie a constant small current to compensate for self-discharge.
Lithium batteries do not deteriorate if left partly charged. Indeed they are best stored long-term at about 50% charge. They do not need or like float charging. If they are cycled between 20% and 80%, they will last for decades.
Another big difference is low temperature charging. Lithium charging systems really need a temperature sensor to avoid charging ar low temperatures. And high temperatures too, actually. Using chargers designed for lead-acid batteries when the temperature gets low is asking for trouble. The best battery management systems will divert to a heater pad under the batteries if the temperature is low, rather than sending the power in to charge the batteries.
