Installing a Nextbase dash-cam using an OBD power cable (1 Viewer)
scotjimland
2,392
10,421
A Woosh bang
Just fitted a Nextbase 522 dash-cam using an OBD power lead
what a neat and easy 'plug and play' hard wire solution..
I was bit nervous about using the OBD port but after reading more about it I went ahead and it works a treat..
Having a 12v permanent supply it can use Intelligent Parking Mode that triggers recording automatically when the G-Sensor is triggered, keeping your car safe when parked.
The OBD power lead is Ā£19.99 .. same price as the hard-wire kit for connecting to a fuse
K9Motorhomers
70
145
North Yorkshire, UK
Swift Voyager 540
Since 1979
I have the 622 and hard wired it into the fuse box using a piggy back fuse holder. Would like to do same as you have but Phantom have wired their alarm/tracker through the OBD. Might look again now. Thanks for the info
scotjimland
scotjimland
2,392
10,421
A Woosh bang
After fitting a trial run and a pickup pulls out without looking.. .. fast forward to 24 secs
JockandRita
11,477
150,381
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Two things for me Jim, ie, my OBD port is the multi pin round type, so unfortunately unable to use the kit.
Also, I keep my audio setting off, as whatever is recorded verbally, could possibly be used to incriminate yourself, should the footage be used as evidence. :(
Cheers,
Jock. :)
scotjimland
scotjimland
2,392
10,421
A Woosh bang
Cheers,
Jock. :)
need to remind Jan not to cuss .. lol
