It's possible I'm wrong. It does seem odd that there's only one modem, but two sets of aerials.Ah, will have to do more research on what aerial connections do what on the RUTX50.
I dunno if Teltonika do this, but I've seen 4x mimo devices that only use 2 antenna feeds in real world (which sounds mad). The important thing is making sure you don't transmit as same time as you recieve as you can receive (as I think everyone who has studiesd radio knows) multiple freqencies simultaneously on a single antenna and ditto transmit multiple at same time. What you usually cannot do is transmit on a single antenna WHILST receiving. The trick is the router obviously receives all 4 frequencies it bonds on one antenna (all different) and transmits on the other in parallel. Now it isn't as good as 4 descrete antennas, but technically it does work.It's possible I'm wrong. It does seem odd that there's only one modem, but two sets of aerials.
So in a nutshell, keep my hands off the wallet and stick with the current roof aerialI'm of the opinion (and as such it is such) that a 4 antenna solution on 5g doesn't add much Kannon Fodda
The logic and reasoning for this, is 4 antennas really only come into play on an iphone as an example when you NEXT to a 5g antenna, as many have poor gain (and thus don't travel well) on the higher frequencies. In fact an iphone antenna only has good gain on 5g frequencies on a SINGLE antenna. Thus 2 with "little" antenna for high gain and 2 on roof with good gain when close will do the job similar or better to an iphone when you NOT next to a tower. I suspect we will not see 5g in rural campsites for MANY years.
However you were right to focus on the LTE category and for remote wifi, a higher cat device as you've found will work far better. Equally ... hate to say it, but turning off 2.4ghz on your router (assuming it offers both 2.4 adn 5ghz) can also help as it stops the slower "clients" congesting. Max speed of 2.4 ghz wifi is for reference around 100Mbit when you have 2-3 clients on the network (yes, I know about 40mhz wifi before people complain, but I also know I only have ONE device capable of doing 300Mbit on 2.4ghz). You need to be using 5ghz, ideally on a second SSID, I think the Teltonica can be configured for that. Any device that "fails" to 2.4ghz will slow the network in effect (so entirely seperateing the 2 frequencies to seperate SSID's networks helps).
Worth noting however in one little small point, THree are rolling out coverage in a single frequency that many 5g chips can't use .. which is more than annoying. (Band 32 is it's name), 1500mhz, so lower frequency than normal band 3 which EE and Three use (1800mhz) for their bulk data. The annoying thing is many 5g devices can't access it, but your RUTX50 CAN (it's one of a very rare breed in this regard).
That was the frequency avaialble 20mhz wide (all of the EE/Three Band 3 is under this), at clubfest which was providing me service when everyone with a cat4 device like your old one was claiming "no service". (It's worth noting this frequency only allows downlink traffic too, it cannot take a single uplink or upload packet). Equally Band 28 I think it is on 4g is also being rolled out by Three (700mhz) ,so goes further than 900mhz like the voda/o2 networks, and even the band 20 coverage EE and Three use). But importantly it's WIDER than the B20 coverage so more data per second.
So effectively as towers get the B28/32 upgrades you are in a great position to use them, and they won't even work on other devices.
The important thing with future upgrades (like B32) is most of them only work when bonded with an existing frequency for more capacity. This requires a Cat6 or higher device with 2 antennas connected. Thats the minimum. You X50 should be able to bond potentially 4 LTE streams together on some networks with 4 full antennas, and this may help in some rural campsites. I would add though I have only found a single campsite we have visited in last year where the diags have found over 3 frequencies to bond ... and that was Burton Constaple above Hull. However with my (2) anteenas on a cat12, it bonded only the 2 "fattest" and fastest frequencies, which is what I would have personally chosen if the device had that level of diagnostics. Those were B28/32 -> and we had > 80Mbit in a rural (busy) campsite on a bank holiday where everyone was watching the Leeds playoff game (given a lot of people from around Hull support or follow Leeds). If I had a cat 4 device it would only have seen the Band 20 coverage, which performed... at about 2Mbit.
Meant to mention on a very brief test of our ZTE MU5001 (ex Vodaphone) with a Poynting MIMO-0003-V2-12 it seemed to improve the signal on both 5g and 4g with a Smarty (3) sim but investigated no further.I had strongly considered the MU5001, but eventually discounted it. There are confused, conflicting reviews over the internal that although it is Cat 22, for anything 4G it only uses it's own internal aerials, and the 2 external aerials only come into action on a 5G service.
Yes exactly, I wouldn't upgrade antenna until it's a commonplace thing to bind 4 antennas.So in a nutshell, keep my hands off the wallet and stick with the current roof aerial
Worth noting that at Thorpe-Le-Soken, Essex, earlier this month, whilst I had no 4G service on the Smarty with the old Huawei (and didn't have the RUTX50 at that point), my Samsung phone on Tesco (O2) was claiming a 5G service and I was happily using that for streaming. There was a big telecoms mast nearby on the Grange Farm campsite.
Also, RUTX50 uses a LTE Cat20 modem and, in order to fully utilize its capabilities, all four antennas are
preferred with identical features.
Remember it'll ONLY use the strongest signal on any port anyhow. It's how mobiles telephony works. The cellular network will always preference the signal with the highest gain on reception or on transmission. The device under hood will be sending status packets every few milliseconds to assertain that. The reason you need > 3 antenna is if you are bonding 3 in parallel in general, which as I have explained in UK is very rare indeed. If it becomes common I'd totally agree with you, and in Europe, yes, there WILL be carriers who bond 4 frequencies. In UK however, this is ludicriously rare, as celliular networks will like to disconnect their busy bands if your device is capable of using a clearer (ie, less customer frequency) rather than allowing you to bond and take capacity on an existing busy band.According to the very first post linked on the Teltonika forums you are better with all 4 antenna ports connected, if spending that kind of money on the router then i would want it powering on all cylinders not just half of them (my view only of course ) as its a fit and forget.
On the Mikrotiks I run with similar featureset I'd leave it manual. And theres a good reason for that Guigsy as ahem EE have a habit of disconnecting cell customers every 12-24 hours. Three however are SUPER stable. You will cause failovers whilst the cell tower "reboots" twice a day and may not fail back if you rely on auto-switching, which is why I don't on one of my sites with EE + THree combo.Ok, so theoretically, all 4 antennas are useful and active. And it doesn't matter which way round I attach them. Good to know there's no point wasting time there.
If anyone does have an RUTX50 with a second SIM (I've got EE and Smarty), have you worked out a good set of settings for the automatic switching? There's lots of parameters to play with. Either it switches too frequently (with the 30 seconds between with no connection while it signs on). Or it clings on to a poor connection. What works in one location is useless elsewhere. So I've been switching manually.
My thoughts are that the teltonika RUTX50 is an expensive piece of kit and making use of all the features would just make sense to me but i get that its more money. I am waiting to install mine but that will happen shortly now i have cleaned the roof. I already have a panorama 5G antenna but this only has 2 antenna ports but i have purchased the poynting 4x4 mimo which will i fit just because i have it.Remember it'll ONLY use the strongest signal on any port anyhow. It's how mobiles telephony works. The cellular network will always preference the signal with the highest gain on reception or on transmission. The device under hood will be sending status packets every few milliseconds to assertain that. The reason you need > 3 antenna is if you are bonding 3 in parallel in general, which as I have explained in UK is very rare indeed. If it becomes common I'd totally agree with you, and in Europe, yes, there WILL be carriers who bond 4 frequencies. In UK however, this is ludicriously rare, as celliular networks will like to disconnect their busy bands if your device is capable of using a clearer (ie, less customer frequency) rather than allowing you to bond and take capacity on an existing busy band.
As long as all ports are connected TO an antenna of any sort (so not hanging in free space, which would damage the antenna port) it's all good.
That would explain my occasional drops on EE...On the Mikrotiks I run with similar featureset I'd leave it manual. And theres a good reason for that Guigsy as ahem EE have a habit of disconnecting cell customers every 12-24 hours. Three however are SUPER stable. You will cause failovers whilst the cell tower "reboots" twice a day and may not fail back if you rely on auto-switching, which is why I don't on one of my sites with EE + THree combo.
Should add my record on a Three sim staying connected to a Cell tower is OVER 120 days.
Location and gain of antenna -> that was the killer at clubfest and why no-ones phones worked AT ALL, all weekend (for most part). And Location is not the key in my view -> O2 in your example with 13 down is likely a very underloaded cell. (given a cat 4 device/cell combined MAX performance is 150Mbit, but 75 in real world). A cat12 device on same sim in same location should as cat12 device get 4 TIMES the performance in theroticial max conditions.. If you can swap your sims in each device and see what you get testing immediately before and after would be a suggestion as the cat4 device should be worse on EE and vice versa. Thats because the cat12 device has an encoding it can use with the cell tower which basically in laymans terms moves more data per timeslot in a cat12 device, an encoding that didn't exist back when cat4 specs were produced.. The complexity here is unfortunatly the lax nature of UK networks, just becuase your device can do a better encoding, doesn't mean in fact your local cell tower has been upgraded to support it, so the answer can be "no change".. A great example is a building in London I was involved in commisioning the networks in (which has a EE network in the building) -> until last year it still only had a single 10 Mbit/sec uplink to the entire buildings cell tower (which only served phones inside that building not anyone outside), but also cruicially only supported the cat4 encoding scheme rather than the improvements made since by more modern cell tower architecture/software stacks. The reason it wasn't upgraded on the encoding was precisely because the towers "uplink" was so weak, and in the city of London getting additional fibre runs in place can take years if the local nodes were fully used (which they were). After I left the uplink was improved to a 10Gbit link... (so 1000x the capacity back to EE) to cover 5g when they deployed that.. Back in day the same cell tower ran 3g using a 2Mbit/sec link, when 3g at the time max perforamnce was about 50Mbit, so the buildings uplink was ALWAYS weak for past 15 years.So much of performance is down to location, i'm currently getting 13 down and 8 up on my Tesco sim in a CAT 4 device and only 3.02 down and 2.46 up on an EE fast as is available SIM in a CAT 12 device. Neither have external antenna attached, but i'm not in a PVC so no Faraday cage effect as far as I'm aware.
Yeah, I've had this at a festival. My phone had a really good signal, but it was so congested, it was useless. My van with a roof antenna could grab a connection to a distant tower that most phones couldn't see. So I was getting a reasonable connection from what it was saying was equivalent to a 1-2 bar signal.Remember at clubfest all the phones were cat20 devices for most part and STILL didn't work becayse the antenna gain was too low and that is the point on antenna gain being the king at times of congestion as if you can pickup a signal at all nomatter how weak that isn't congested you can beat the local towers congestion.
That was my point 18Dbi in east yorks below Brid you can pickup like 5 towers in Brid on EE/Three, 3 from driffield, 1 from Brandesburton and 2 from hornsea. Likely could make hull or Grimsby too via the sea, but not really cell locked those (yet). A phone gets 1 bar off the hornsea band 20Yeah, I've had this at a festival. My phone had a really good signal, but it was so congested, it was useless. My van with a roof antenna could grab a connection to a distant tower that most phones couldn't see. So I was getting a reasonable connection from what it was saying was equivalent to a 1-2 bar signal.
Migraine now?My head hurts now
Theres another point which us hams are aware of btw, it's attenuation -> if you have too much gain (ie, ALL The antennas use a roof antenna with same gain), then what happens if you visit in a city at a site NEXT to a cell tower, as you end up picking all the other "localish" towers on the same frequency as well as the "strong" local signal. Then your gain may overload your receiver/mifi and cause "less" performance than a antenna with lower gain like a phone. This is a reaosn why some roof antennas give less performance than a phone in a city when you may be next to a lamppost providing 5g, and why connecting all 4 antennas can actualy be worse for you than ahem, not.Ok, so theoretically, all 4 antennas are useful and active. And it doesn't matter which way round I attach them. Good to know there's no point wasting time there.
Yeah, thats awful, so you are getting crappy signal on band 3, -100 or less is what you want for decent > 20mbit perofrmance. I'd say that is proving you need a roof antenna, as even a crappy one at 500 metres should give > 20Mbit. Remember DBI isn't everything, I usually look for the CQI score that usually kicks in at ~ -100dbi -> if you not getting a CQI score of > 10 you not using the best codec for data. QPSK is the cat4 (only codec) and 64QAM I think was made avaialble from cat12. But if you not getting a CQI of above 10 you will usually get under 10Mbit. The code rates below roughly equate to how much data you can move per "timeslot" on a cell.Network cell info says I'm getting -120 dbm on band 3 EE which is pretty poor, I don’t think i'm all that far from the tower 557 mtrs according to cell tower locater, maybe i'm in a bit of a dip?
So to update this thread I bit the bullet and acquired a RUTX50.
Running a Smarty data only sim (which uses Three), at Newark Show I was averaging about 10mbps on a 4G service. This was using my existing roof aerial, the 2x2 Panorama thing, as above. OK so that speed is nothing to get excited about, but at least I could stream TV.
By comparison the Huawei was struggling to get any connection, and at best it was 1mpbs. Useless. Worth noting that my neighbours on the rally field also using Three based services were struggling for connectivity via various phone, router and aerial setups.
The higher Cat 20 of the RUTX50 seemed to be achieving something, although I didn't probe settings to establish exactly what bands were connecting. Of course only two of the four aerials led to outside, the other two had the provided basic indoor aerial stalk things, which no doubt achieved very little given the internal faraday cage effect prevalent in my PVC.
I had strongly considered the MU5001, but eventually discounted it. There are confused, conflicting reviews over the internal that although it is Cat 22, for anything 4G it only uses it's own internal aerials, and the 2 external aerials only come into action on a 5G service. Certainly there seems to be one company offering a modification service to add external connection ports to the ZTE device. So potentially, inside my PVC faraday cage, the MU5001 on internal aerials would perform worse than the Huawei I was trying to replace. I decided to play safe, spend the extra money, and go belt and braces for something that is clearly compatible, the RUTX50.
I will now consider whether to upgrade the rooftop aerial to a 4x4 mimo device. More decisions.
Be interested when you do test with 4x4 if it's slower when you park next to a cell tower (I can suggest some sites, Great Yarmouth CAMC is a great one as the 5g tower for EE and Three is LITERALLY as you drive into the site). Given that area has "lots" of 5g, high gain on roof may be a bad thing... (ditto in London). I'm seriously considering actually taking 4 stubby antenna for the X50 (or whatever 5g device I go for) to cover picking up signal too far away in this case (ie to limit interfereance from high powered local cell towers).From the testing we did when developing our own 4x4 antenna, we found that it was giving us speeds of around 25%-40% higher than the 2x2 on 4G and 5G. I'd also expect this performance gap to increase as more and more 5G infrastructure gets rolled out. I'm not aware of any of our customers that have gone to the trouble of removing a perfectly good 2x2 to swap with a 4x4 to get an extra 50mbps.
