Ignition on - no power - help! (1 Viewer)
Jan 18, 2019
608
1,008
Cuesta Blanca, Murcia, Spain
Hymer Exis
Stopped for lunch in a thankfully shady layby (in France)
Apres lunch, turn the ignition key and nothing. No click.
The radio is powered from the fiat battery and that was on till I turned the key.
So I'm thinking blown fuse.
Any advice anyone, or do I just have to test all those that I can find .. ?
Are there any big fuses adjacent to the battery under the passenger's seat ?
(I have a power-pack that should start the vehicle if the fiat battery is depleted)
Nigel Crompton
Jan 18, 2019
608
1,008
Hymer Exis
Update.
Put a meter across the jump start terminals, 13.1v. There's a gizmo that trickle charges fiat battery from solar, but doubt that this is solely responsible for this voltage, so assuming battery is good.
Returning to cab, I find the radio is now on (it's powered from the fiat battery via a dash mounted isolation switch) - but has reset to factory settings.
Tried ignition again, and dashboard lights up on first click, as it should. Not tried engine start yet.
So, not a traditional fuse. Are there any thermal cutouts anywhere ? Vehicle has operated in much warmer climes in the past.
Nigel Crompton
Jan 18, 2019
608
1,008
Hymer Exis
Dodgy earth cable perhaps🤷‍♀️
Rudski01 wins the prize.
The battery's earth terminal has a little bus-bar with 3 terminals; 2 in use.
1.The main earth strap's connection to the bus-bar hits the top of the battery case before the clamp is fully home on the terminal. Nowt I can do about that ATM.
2. Two more cables at the other end of the bus-bar were preventing the clamp fully closing; the lever contacting the corner of the battery case. There was only 1-2mm in it, it was probably fine with the original battery.
The clamp had worked loose; not falling off loose but, it seems, enough to generate a significant resistance.
Moved the two cables to the center terminal (13.26v across) and reattached clamp. Started engine twice, seems good.
Nov 19, 2017
205
18,013
Hobby Siesta
Since 1989
File a little off the end of the clamp so doesn't touch, maybe?
