Holes should always be drilled to stop spreading regardless of how the repair is done.
Been having a look around on here for advice \ recommendations on what to go for and on tinterweb for availability and pricing.
I just in the middle of fitting these. I also fitted some on the old van.
On the "to get list". What size of hole \ drill is required for fitting?
Biggest problem at the moment is fishing the sensors out from behind the bumper, its so tight against the body.
The way I'm skelping the panels off the motorhome this ain't gonna be a problem!
Would not do without them - even though there is a camera fitted as standard.
Yip, will be fitting in addition to the camera.
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=264393557739
Yes, definitely fixable.I've been thinking about fitting reversing sensors on our 2013 Autotrail motorhome.
Having decided to cancel our forthcoming jaunt to D&G as a result of CV I thought I'd better take the motorhome out of storage for a wee spin to ensure batteries were fully charged having just had to get the airbag ECU reset.
So, off we go out along the motorway for half an hour or so and same back to storage.
Reversing back into our storage pitch, and given it was earlyish morning with the sun at a low angle (yeh, I know - sun, never in Scotland!) dazzled in the mirrors and reversing camera.
And, you've guessed it!
As you can see, I've got the bit that's broken out as well.
Question for the gang is, is it repairable or is it a new panel?
After trawling about on here for previous posts I was kinda thinking maybe seeing if I could get some ABS pieces (it is ABS or similar and not fibreglass) and MEK and sticking these to the back of the panel over the cracks (full access is available in situ behind the panel). And, maybe, some wet and dry paper to ease off any irregularities left on the face.
What's the thoughts?
Waiting on the resin curing fully and will be done tomorrow (all going well)!Decided not to drill at the end or cracks?
Not far away from how I repaired a cracked Rear Valence on My Last Motorhome. The reinforced glass matt makes a good job better.The way I repaired my plastic fairings after a off with the bike:
Glue the bits together. Sand at the back and add a metal mesh ina fibreglass mix to reinforce it. Fill the missing voids with melted abs. Sand down and spray fill with plasticote few times. Then spray the colour.
But his was over two years ago!Thats a great job.
And I thought I was the first!!
Don't be silly!And I thought I was the first!!
