i am assuming thats a standard installation method ..?
i thought that as its the DC to DC charger that does the work and kicks out the 60A, then 25mm2 to the DC to DC should be sufficient?
It’s not just the amps. The voltages will be wrong. The B2B will think the battery is at a lower state of charge (voltage) than it is because of the voltage loss on the cable and the battery will never get fully charged because it won’t receive the right voltage from the B2B.i thought that as its the DC to DC charger that does the work and kicks out the 60A, then 25mm2 to the DC to DC should be sufficient?
MisterB, Take the negative of the chassis near your leisure battery, and to the b2b input.
With my leisure batteries in the rear garage, that's how I did mine, with a positive feed running all the way along the chassis, from the starter battery to the B2B input, (fused at each end) then a short positive feed to the batteries, again fused.MisterB, Take the negative of the chassis near your leisure battery, and to the b2b input.
