I had a similar problem with my 3 and Huawei B535 when we went to Jim’s, we had the best signal,Factory reset the tv, firestick and mifi. I've only just discovered my android phone will stream the same progs without buffering using the same mifi.
You should be able to go into your router settings and change the channel manually, usually channel selection is set at automatic as a default, but you should be able to select a channel manually to see if that improves the performance.The only thing I can thinks its a problem with what channel the router locks onto.
Just had the reply below from Camino…what a great deal.
I’d better start streaming in 4K to use up the March 300gb in the next seven days
“Hello Martin,
I have just asked to cancel the Service of the sim card 1.
You will get 300GB with your sim card in March and data will renew the 1st of April with 300Gb again.
Best regards
Camino”
It resets at the start of each month. If you join mid month, you get charged pro-rata for the days used up until the 1st of the next month. Not quite sure whether this is just a daily rate or whether it also takes into account the amount of data used as well.Does the plan run from the day that Camino activates it until the end of the same month or, does it start from the activation day for 30 days?
Perfect - thanks !It resets at the start of each month. If you join mid month, you get charged pro-rata for the days used up until the 1st of the next month. Not quite sure whether this is just a daily rate or whether it also takes into account the amount of data used as well.
There is one totally perfect solution that works every time…
Turn off the telly and go for a walk or read a book or take some photos.
Works for me 100% of the time and saves all that time and effort and frustration worrying, configuring, resetting and failing
Hi …… I think I saw the answer to this but can’t find it now. Will they post to uk and can it be activated here or will it need to be done in the EU ?We have been through this already, see post #33
I appreciate not everyone wants or ‘needs’ high volume data, but there is a significant proportion of Funsters who, when enjoying their MH travels, also enjoy decent internet access. This offer is for them…
Edit* think I’ve found the answer now
Kind regards
Chris
Better off with the OP's deal IMV.Has anybody used the French provider HIPPOCKET?
https://hippocketwifi.com/en/long-term-pocket-wifi/
For modest users like me who prefer a small, pocket MIFI similar to HUAWEI this scheme offers a rental MiFi with rates tailored a bit more to travel duration and use. We only need a tether facility to a laptop and phone to do a few emails and calls, and a bit of searching for places to stay. I am with Three but their charges are annual and a tad exorbitant as we only use a MIFI for a couple of months travelling in Europe. 120 Euros for 3 months small use?
Anybody had experience of HIPPOCKET please?
Many thanks HarveyHello Chris
It’s a yes and a yes. Postage to anywhere inc UK and it can be activated anywhere in Zone 1 inc UK.
Regards
Harvey
Only if you continue into a 2nd month. Otherwise you pay in full for the part first month.If you join mid month, you get charged pro-rata for the days used up until the 1st of the next month.
We used Free data sims for 3 months in France last year and my hubby streamed Netflix for several hours every night without any problems (near to Limoges). I’m sure it will be fine, and if not it’s easy enough to cancel.Sorry, but I have no idea what you're talking about - I just want a large amount of data per month for streaming TV whilst in France, mainly for the Vendée where our static caravan is sited. Are you suggesting it's not that good ? If so, is there a better alternative that I can get set up and working within the next five weeks while I am in France?
Carpmart
If my Tesco sim falls through I will go with this. Quick question, has anyone living outside of Spain managed to set up payment with a credit card? I would want to use my Halifax Clarity.
Chris
Took the plunge on Tesco Mobile earlier. Unlimited data for £17.50/m and still no roaming charges in most of EU.I'm currently using a Tesco mobile unlimited sim card, i can use as much as i need in Europe for a maximum two months in every four, i have been in France for 1 week so far and have used 66.4 GB, i'm near Mont St Michel and am getting speeds of 41.9 Mbps down and 9.46 up so it's not throttled either. I'm going to be away around 2.5 months on this trip so will see how strict they are on the two months but maybe if you're using it in the UK as well they'll be okay with it, we'll see.
Edit: I'm not saying the deal you got isn't a good one, obviously if you're going to be away longer than two months it is a good solution.
Just had an interesting exchange with Tesco mobile advisor. He says that the Home from Home (HFH) service you mention is good for motorhome holidays. But he also said:Took the plunge on Tesco Mobile earlier. Unlimited data for £17.50/m and still no roaming charges in most of EU.
I'll apologise now because it will probably cause Tesco to start roaming charges in anger. Went full time the week before Covid lockdowns started 2 years ago, fitted a diesel heater the week before the fuel shortages the other month so my track record speaks for itself![]()
Also saves having to use a VPN etc.
You don't need a vpn, I'm in Spain at the moment using a Tesco mobile unlimited sim and I can stream all uk tv services without a vpn.Will it? You’ll still be connecting via an overseas service provider, so U.K. based streaming services etc. that operate geographic restrictions will know that you are not local.
