Tootles
Jim, I've recently been having the same problem as Rory had, and thought the same re contacts and WD40, but it has manifested itself even more now, and doesn't work at all. This coincides with the ignition light glowing every now and then, until Friday, when the alternator packed up altogether. That's when the step buzzer stopped working too.I would think that is the step switch that is dirty/sticky or corroded connections.
.. clean a spray with WD40 should sort it..
Thanks Jim.seems unlikely that the two problems are connected... I'm thinking coincidence.. could be wrong of course ..
keep us posted and good luck getting the alternator done
I thought Hymer B-class vans had a step-retracting switch on the dashboard as standard. Mine is a 2003 model and has one. It is to the right of the steering wheel (LHD) but will only retract the step, not extend it.
Just been out to check in case I had missed it .. but it's definitely not fitted on mine .. 2002 model .. also checked the manual and no mention of it ..
Yep, I was right about the two problems being connected to the faulty alternator.Thanks Jim.
I'm certain the two problems are connected, as the buzzer used to sound, and the ignition light went off instantly when the engine was started. Recently, the engine has need a blip on the accelerator to extinguish the ignition light, and only then does the buzzer sound.
Cheers,
Jock.
