- May 1, 2008
- 19,566
- 51,432
- Burstner Privilege T
- over 50 years
Brilliant Carol and Jim...
That's what Motor Home Fun is all about.
JJ
JJ
@scotjimland I've been making good progress following your very helpful photos and instructions and I'm now ready to remove the main frame .. I'll take your advice about using the W4 mastic roll .. I see there are several widths, 19mm, 32mm and 45mm - do you recall what width you used?
Did you have to disconnect the battery wires before attempting this?Went out today to check all was ok and found a drip on the floor under the big roof light.. it's about 800x 500mm and cranks up and down parallel to the roof..
my hopes that it was just a bit of condensation were dashed.. I found the cassette that holds the fly screen and blind very wet..
I decided to remove the cassette to investigate and found it full of water .. so not just a bit of condensation..
I was hoping to do from inside the van, but the window gets in the way, it only lifts up a few inches which makes it hard to get to the trim screws on the outside..
So I removed the window, then the external aluminium trim , cleaned off all the mastic from both it and the roof.. used a scraper, then green scouring pad soaked with white spirit.
Fortunately I had fresh roll of W4 mastic and proceeded to apply it to the ally frame..
While doing that Jan said she would clean the window.. this is where disaster strikes.. I went to help and flipped the window over to clean the inside and struck the edge of the table with it and a big bit broke off and fell on the ground..
I suppose it could be repaired.. but i noticed a couple of other cracks.. maybe caused by striking an overhanging tree branch.. who knows.. but if it broke that easily I reckon it has suffered UV degradation.. and better replaced .
I made a temporary repair with gaffer tape and stuck it back on the roof.. and replaced the rest of the trim and cassette blind..
I dread to think out how much a new one is.. I'm waiting a call from Becks with a price..
It's not a difficult job.. but when we get careless.. disaster is waiting to bite us on the bum.. a hard lesson..
A few pics of the job in progress .... View attachment 80886 View attachment 80887 View attachment 80888 View attachment 80889 View attachment 80890 View attachment 80891 View attachment 80892 View attachment 80893
Scotjimland moved over to the dark side (caravans) a few years back and is no longer a member but to answer your question, no you don't need to disconnect the battery just turn off the light switch for the integral lights before you start.Did you have to disconnect the battery wires before attempting this?
