scotjimland
- Jul 25, 2007
- 2,656
- 11,825
- None
Went out today to check all was ok and found a drip on the floor under the big roof light.. it's about 800x 500mm and cranks up and down parallel to the roof..
my hopes that it was just a bit of condensation were dashed.. I found the cassette that holds the fly screen and blind very wet..
I decided to remove the cassette to investigate and found it full of water .. so not just a bit of condensation..
I was hoping to do from inside the van, but the window gets in the way, it only lifts up a few inches which makes it hard to get to the trim screws on the outside..
So I removed the window, then the external aluminium trim , cleaned off all the mastic from both it and the roof.. used a scraper, then green scouring pad soaked with white spirit.
Fortunately I had fresh roll of W4 mastic and proceeded to apply it to the ally frame..
While doing that Jan said she would clean the window.. this is where disaster strikes.. I went to help and flipped the window over to clean the inside and struck the edge of the table with it and a big bit broke off and fell on the ground..
I suppose it could be repaired.. but i noticed a couple of other cracks.. maybe caused by striking an overhanging tree branch.. who knows.. but if it broke that easily I reckon it has suffered UV degradation.. and better replaced .
I made a temporary repair with gaffer tape and stuck it back on the roof.. and replaced the rest of the trim and cassette blind..
I dread to think out how much a new one is.. I'm waiting a call from Becks with a price..
It's not a difficult job.. but when we get careless.. disaster is waiting to bite us on the bum.. a hard lesson..
A few pics of the job in progress ....
