Cheaper but not as quiet.running an efoy means another fuel to carry .A suitcase gennie running on gas always seems a better option and cheaper
The solar panels need minimum light to offer charge to your leisure batteries. That does the panel say they are charging at? Maximum I think should be 14.3v. Have you checked the batteries, it might be they are past their sell by date.Hi hoping someone with more knowledge than me can explain what I have and if it's suitable for off grid camping.
I recently purchased a Hymer Grand Canyon S fitted with two 95 amp hr leisure batteries with the following Schaudt equipment.
Charger LAS 1218 S
Electroblock EBL 30
Booster WA121545
All instruction are in German, so not sure exactly what they do?
Plus 200 watt solar panels.
Only used the van once so far off grid and after three days batteries were reading 25 % on the control panel.
Admittedly solar input was minimal as it
rained solidly and we ran the diesel heating for long periods, the van also has a compressor fridge.
Am I expecting to much of this set up and if so any suggestions to extend battery use before resorting to electric hook up.
On my DT201 I can set the battery capacity to over 400Ah at least. If the 'nominal' capacity is set to 230Ah, then the display SOC will show 80% of that, ie 184Ah. This is to avoid discharging below the 20% level, which is bad for lead-acid batteries. When the display reads 0%, there is still 20% left in the batteries. Once you know that, you can work round it, but the SOC, ie the amp-hours going in and out of the batteries, will be accurate. Assuming all the charging goes through the EBL, of course.The control panel on mine (DT201) normally shows the Ah of the leisure battery but it only goes up to 180Ah max so doesn't give an accurate reading any more through the EBL shunt of the battery capacity.
Thanks for that! You learn something new every day. I thought I had read in the Hymer manual that 2x90Ah batteries was the max allowed so hadn't tried altering that parameter. So if I pretended that my 230Ah lithium was 460Ah the battery cut off would occur at 20% which would effectively be 10% SOC of the lithium?On my DT201 I can set the battery capacity to over 400Ah at least. If the 'nominal' capacity is set to 230Ah, then the display SOC will show 80% of that, ie 184Ah. This is to avoid discharging below the 20% level, which is bad for lead-acid batteries. When the display reads 0%, there is still 20% left in the batteries. Once you know that, you can work round it, but the SOC, ie the amp-hours going in and out of the batteries, will be accurate. Assuming all the charging goes through the EBL, of course.
Thanks for this!The EBL 30 is (I think) a 240v charger, the LAS 1218 is an additional 240v charger which will plug into the EBL 30 to provide an additional 18A of current when on 240v to the leisure battery. If the 1218 S has a lithium setting that would be fine. You could then disable the charger in the EBL 30 by taking out the 20A fuse so that only lithium profile charging occurs as although gel profile charging is ok it's not ideal (to do with float charging I think).
I have found however that I don't need to use the EBL 101( in my case) for 240v charging at all as the sole and B2B provide adequate charging so you may find you don't either. Alternatively you could buy a Victron charger with lithium settings and run that through the additional charger block on the EBL (or run it directly to the habitation battery avoiding the EBL)
The control panel on mine (DT201) normally shows the Ah of the leisure battery but it only goes up to 180Ah max so doesn't give an accurate reading any more through the EBL shunt of the battery capacity. This doesn't really matter as I can see the voltages which are accurate and I have a BMS with Bluetooth on my 230Ah Roamer battery to give me an accurate SOC .
I don't think that would work as you would expect. You want it to read 0% when you have taken out 90% of 230Ah, ie 230 x 0.9 = 207Ah.So if I pretended that my 230Ah lithium was 460Ah the battery cut off would occur at 20% which would effectively be 10% SOC of the lithium?
Just applying a random voltage is not the same as float charging. A lead-acid battery has a 'resting voltage' of about 12.6V. If a voltage of less than the resting voltage is applied, then charge will flow out of the battery. If just equal to the resting voltage, nothing flows in or out. If more than the resting voltage, then charge will flow into the battery. The idea of float charging is that just enough charge flows in to make up for the internal self-discharge of the battery. Typically 13.4V is about right, but it depends on the battery type, and the acid concentration.What about the gel charging profile is not ideal for lithium, you mention something with the float charging? What would be ideal in terms of V and A?
