Hymer B654 (Fiat 2.8 JTD) - Dashboard Dismantling (1 Viewer)
Lizbiebrowne
333
431
Teesside
Hymer B654
Since 2019.
I noticed a small pool of water under the passenger footwell that looks very much like coolant. I suspect the heater matrix is leaking and I understand I'm going to have to remove a lot of the dashboard to replace it. Does anyone have any experience of this?
Feb 22, 2011
9,800
20,197
Newcastle under Lyme
Hymer B544 A Class
Since 2015
I have read of others having gone down this route and it doesn't make for happy reading.
I gather it's a sod of a job and that's putting it politely, but I have no first hand experience so could easily be mistaken, I hope so.
A search may pull up some threads
Dec 24, 2014
9,224
47,633
Hurstpierpoint. Mid Sussex.
Compass Navigator
Ever since lighting was by Calor gas.
I don't know your vehicle so it may not be suitable but when I had a heater matrix leak in the past I have used some leak cure in the cooling system as extensive dismantling (grovelling upside down in the footwell) would've been required to access the matrix.
2,001
1,127
Bracklesham Bay, West Sussex
PVC
There is information , that may help , regarding stripping out the dashboard on Fiat Ducatos etc that can be downloaded in the Motorhome Technical Articles section of Resources (bottom of this page ) , .
Nov 4, 2011
5,944
39,066
Uk
I don’t know the age of your Hymer but our 2001 fiat based B584, the lower part of the dash is easy to remove, only about 5 screws
Jan 10, 2015
229
449
East sussex
2002 Eura mobile
Since 2014
Ok, mine’s 2003. Does removing the lower part give access to the heater?
Like you I had a leak in the heater matrix on My 2003 2.8jtd ducato. I bought the replacement matrix & started the process of getting the old one out. After much cursing & two days I gave up. I took out almost the complete dash & still it wouldn’t budge.
After putting it all back, a miracle in itself everything worked. I then bought some kseal from euro parts. Cured! Still good after 4 years.
L
Lizbiebrowne
333
431
Teesside
Hymer B654
Since 2019.
Thanks, in stock at my local Euro Car Parts. I’ll get some today and try it. If that doesn’t work I’ll go down the removal and cursing route.
