Hymer B544 2012 Comfortmatic (1 Viewer)
May 31, 2015
11,726
44,676
Cornwall
Ducato PVC
Getting Better
An excellent opportunity to acquire a well sought after motorhome with the layout and accessories for full time living or long periods away with all the facilities onboard for self sufficiency.
Hymer B544
Left hand drive 3 berth 2012 6.5m long 2.35m wide 2.9m high.
Fiat Ducato Maxi Al-ko chassis 4250kg with lots of payload.
150hp Euro 5 2.3 Multi-jet ll engine
Comfortmatic robotised semi-automatic gearbox
Cruise control, hill holder, ABS, ESC and Hill decent.
16” Alloy wheels with new Michelin Aplin 3 peak winter tyres including the spare with same. 225/75R16c 121/120 R
Front fog lights
Exterior is in Sierra Grey Metallic with Champagne wheel arch’s and skirting trim.
On the exterior of the motorhome is a covered lockable fuel filler cap, covered lockable water filler cap, covered electric hook-up Point,
Gas-low filler on the Gas locker door.
Thule Omnistor 8200 Electric Automatic Awing with a Remote control size 4.5m x 2.5
A Waeco Reversing Camera with auto shield.
Fiamma bike rack for two bikes.
SOG housing on the cassette door locker.
A Lockable external barbecue housing point with bayonet fitting.
Electric steps for the rear habitation door and drivers door.
On the roof we have an Oyster Vision lll 85cm Automatic seeking satellite dish and digital receiver with remote control and Sat-mouse.
3x100 Watt quality Solar panels that feed their own 3x Victron MMPT 75/15 regulators so if a panel is shaded you will still get power.
To compliment the Solar system is a Victron BMV-712 smart Bluetooth battery monitor.
A quality Dab Ariel.
In the interior.
The interior fabric is Palermo, with the front seats being Aguti fully adjustable swivel seats.
Front drop down bed which kingsize fitted sheets fit perfectly with skylight and twin LED reading lights, magazine/bits and bobs holders.
Plenty of aircraft style head height lockers with under storage.
Tv swing arm mount.
LED lights throughout.
The Cab front has Automatic Air Conditioning with dash cooler small glovebox and a larger central lockable glovebox.
Switching for the retractable hab step with alarm, controls for the fully adjustable heated coach mirrors.
Storage areas with large cup/bottle holders for driver and passenger, storage cupboard on the passenger side.
Two 12v points.
A New Pioneer double din head unit with CD, DAB, Bluetooth, phone mike and USB for connecting accessories/phone.With up graded speakers.
The unit displays the reversing camera view and can be operated while moving or engine turned off.
A Hymer premium up graded table which gives more space but is fully extendable which swivels with side to side movement.
Large Dometic AES 160ltr fridge freezer RMD 8505 recently serviced with new cooling paste change and applied. Large cupboard above which houses the 3x Victron solar monitors.
3 ring gas hob with electronic ignition
Four large pull out kitchen drawers that house a bin, cutlery draw and compartment draws for crockery, saucepans and food, two cupboards above.
Double wardrobe, coat hanging space with cupboard under for storage and also houses the 240v fuse box.
All windows/skylights have blinds and mosquito nets including the hab door.
The toilet/shower compartment house’s an electric flush toilet which has a level indicator, a large wheeled cassette that has a professional installation of a SOG system installed and spare cassette, a large bathroom cupboard, sink and shower with an ingenious moving door that gives a large shower compartment with duck boards in the shower tray.
Technical:
The comprehensive solar system supplies power to two new Exide G80 80Ah Gel Batteries (the last AGM’s lasted 7yrs) with a battery master that supplies a charge to the bosch S5 019 100ah cab battery.
Victron BMV-712 Bluetooth monitor that you can view and control on your smartphone.
Waeco 1512 Pure sine wave Inverter with remote and priority supplying 6 mains sockets.
Additional 12v power points and USB power sockets with volt meters displaying real-time voltage of the habitation batteries and the cab battery.
Gaslow LPG system with two 11kg cylinders with auto/manual changeover and external filler.
Vanbitz Growler alarm system covering all doors and lockers with bike/accessory loop
Vanbitz strikeback Non starter system with pager and locator tracking system, this alarm is controllable through your phone, you are able to arm, immobilise and track the vehicle with your phone and it will call you if the alarm is activated and give you information on entry and location of the vehicle. The ongoing cost of this is just a top up of the SIM card. I usually put around £10 on the sim yearly. Fully transferable.
Dometic key operated safe.
120ltr fresh water tank, 100ltr waste tank. Both tanks are located between the double floor which is heated for winter use. Many floor storage cubbies one of which is deep and large ideal as a wine cellar.
The vehicle has an extensive service history throughout its 70k mileage and has never given any concern or trouble throughout my 3yrs of ownership. The motorhome was bought for cash (no finance) from an existing funster of Motorhome fun and has a full investigative history. The V5 shows one former keeper since 2012.
I have the all important COC (certificate of conformity)
All manuals for all the equipment, paper and digitally.
All mots and service receipts and lots of other paperwork associated with equipment and the motorhome.
I have many spare keys.
Full carpet set which I have not used.
Mot expiry 26-11-2020
Tax is £165 per year
This motorhome has been a joy to travel in around Europe without any hiccups at all, what ever it needed was done and more. Being only 6.5m long it does fit in most parking spaces if you can get it in backwards for the short overhang, I’ve been all over Europe including up in the Pyrenees and have got where ever I wanted to be.
I used to get an average of 31mpg tested over 10k miles with continental tyres, with the new Michelin tyres I appear to be getting around 28-30mpg so far but have done little miles on them.
I never had to plug in to EHU unless it was in with a pitch price, it is very comfortable with the large layout and having friends around for dinner, there is a third pull out bed from one of the benches. There are four seatbelts. It is very well insulated and is very warm in the winter and cool in summer.
The satellite system is excellent and I have had U.K. tv down as far as Benidorm. The 22’ tv is not in the sale as it has a problem but it works as it should and can be in the van when sold
The Motorhome is in very good condition but does have signs of wear and tear according to its age.
I am disabled and the motorhome has disabled hand controls professionally made and fitted which just bolt on and can easily be taken off which I can do. The motorhome can still be driven with them on by anyone as the foot pedals are not affected and if needed the controls can be left on.
Awaiting a wash and polish
This is a very reluctant sale for a very genuine reason.
I am in Cornwall And will be as accommodating as possible for anyone to view the Motorhome which is located on my drive near Truro/Redruth. I can pick up from a train/bus station or Newquay airport and can even accommodate serious buyers. I can send pictures of what you need to see and can also video call and show you around it.
Any enquires please pm me.
£48,000
3,064
7,084
Hymer Exsis
20 years
That will make someone an amazing motorhome with all the bling ever needed!
old-mo
Extra Special
16,343
93,693
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Gorgeous van with all the add on`s and toy`s...
Good luck Smiffy with the sale.. :hugs:
You did not have that when you stayed with us.... did you..???
And I love the way they have even given you a spare toilet seat with that model.. (y) :RollEyes::wink:
Just smiffy
May 31, 2015
11,726
44,676
Cornwall
Ducato PVC
Getting Better
yes, it was parked on your drive, a lovely van and I will miss it dearly...:crying:
Apr 30, 2018
1,995
4,425
Mid Suffolk
Adria Matrix 670DC
Motorhoming since 2018.
As everyone else has said, a lovely MH. The time and effort gone in to preparing the sale details are a credit to you. Even taking the current climate into consideration, can't see this hanging around for to long. put a private plate on it and could pass for a lot newer model. Good Luck with the sale.
Oct 29, 2016
4,509
52,952
Surrey
Carthago C Tourer
Lovely van, in great condition, with all the bells & whistles also.
The Furniture seems to be much more sturdier than the new ones, and not an inch of storage space wasted.
Sorry that you are having to sell for what ever reason, you will miss it I am sure.
Best Wishes.
Les & TinaL
Jan 31, 2016
1,902
3,382
Alness, Cromarty Firth
Hymer B544 (2012)
newbie
Having similar model, I think I'll pinch your advert if or when I sell mine, perfect description. This model does everything you could want for two people (and a George Pointer), we wild camp in ours 95% of the time and find perfect.
Good luck with the sale, I'm sure who ever buys this will love it.
bobandjanie
8,173
15,840
Javea, Spain
Pilote V600g
Very sad for you Garry but needs must, I think the first thing I said when we saw it was what an immaculate motorhome, obviously been loved since new, and had plenty time and money spent on it, I would like a pound for every journey we made when the dealer describes something as immaculate, and you get there and it's cr#p, we went from Norfolk to a dealer A K in Devon he offered a reduction and then another £1000 on the part x, ? we never went all that way to buy a heap of crap. ?
Having seen and been invited into yours, I can say it really is immaculate and something to be proud of owning, good luck with the sale, I'm sure someone is going to be very pleased. ? Bob.
Just smiffy
May 31, 2015
11,726
44,676
Cornwall
Ducato PVC
Getting Better
I'm a bit puzzled over this though, Large Dometic AES 160ltr fridge freezer RMD 8505 recently serviced with new cooling paste change and applied.
I think your talking about the cooling paste...? The aluminium fins on the fridge were taken off and the old transfer paste taken off and new paste put on. This means that I used a better product and more of it then Dometic used and now the fridge works better and more efficient.
This thread describes it somewhat...
Nov 17, 2012
1,930
2,614
WEST SUSSEX
HYMER B SL 674
SINCE 2005
The B544 is a brilliant Hymer model if anyone is sitting on the fence go for it. We had the same Model year and most of the mods except 3l manual for 7 years and loved it. Well made etc. the only issue it seems to have a spare wheel in my wine cellar!
