Thanks for posting the videos, we found them to be a useful reference. I see you had Humberto uprated from 3500 to 3850. Out of curiosity, did you take it to a weighbridge prior to doing so? If so, any idea what your payload was with the 3.0l engine upgrade prior to being uprated? I'm guessing the 3.0l lump is circa 50kg heavier than the 2.3l?
I have the same model, with additional Leisure battery, awning, satellite dish and solar panel, 75% fuel and empty water tanks mine weighed 3300 kgs.
Thanks, this confirms my gut feel / fear. We were looking a the same model this weekend plated at 3500, which emotionally I was quite drawn too. However, uprating the weight is not an option due to licence restriction, so I'm going to have to decide with my head rather than heart and explore other options. Bugger.I have the same model, with additional Leisure battery, awning, satellite dish and solar panel, 75% fuel and empty water tanks mine weighed 3300 kgs.
Enjoyed the info., photos and videos. Thanks Lee!
Are there likely to be any issues with Le Shuttle and the Gaslit system. Seems to me that there shouldn't be, but there are restrictions on LPG powered vehicles, I think. Can you or anyone advise?
The DLR's are not linked into the bulb failure circuit so you don't need ballasted LED's standard ones will work but ensure you buy "E" marked bulbs, cheap ones have a poor light spread and if not "E" marked they are illegal.Hi Mike,
Can you let me know which LED bulbs you used, and where to get them from, for the running lights? I've been looking but I understand they have to have resistors to fool the Canbus.
(2014 B544)
Tim
When using the tunnel, the only check they do is to check the bottles are turned off, we have 2x 11kg gaslow bottles. We crossed on 29/12/16Does anyone have experience of the checks they perform on fixed bottles/tanks? I've only ever crossed with Calor/Campingaz type bottles before.
A common fault with those taps, normally enough slack in the wire to pull up a bit and solder them together that what I did on one of our vans sleeved the joint with 1mm silicon sleeving.Just had a problem with the kitchen sink tap. We were just getting a trickle from it, although the shower and washroom taps were fine.
I opened up the water tank cover and listened....the pump wasn't being activated by the kitchen tap which indicated an electrical problem.
Being the sort to delve into things I unscrewed everything I could from the tap and all was revealed.... a broken wire from the pump micro-switch.
View attachment 154096 View attachment 154097
I have soldered the wire together and added insulation tape but I'm actually surprised it lasted this long. Both wires are continually being turned and twisted by the action of the tap handle.
I ordered a new switch and wire assembly from Ebay (£9) which will go in my spares kit.
What I may also add is a simple in-line switch to the spares box. That way I can always cobble together an on-off switch for the pump whichever tap failed.
Info. The way the Hymer system works is that the taps function like a normal tap EXCEPT that, when you open them, the first thing that happens is the small micro-switch turns on the pump. Once the pump is activated the tap works as normal. When you close the tap it shuts down the water flow until the point it finally trips the micro-switch again, turning off the pump.
If all else fails you could simply cut the black and brown wires from the switch and touch them together to turn on the pump. Some people actually do this by fitting a simple in-line switch on a kitchen unit somewhere.
The number on the microswitch is 1055/58 and can be used to find replacements on the web. You can pay lots more than £9 delivered if you search on Hymer Microswitch. I've seen the same thing for £25. I'm sure you can get them for less than £9 as well.
Anyway..end of tip.
