Huawei phone not charging (1 Viewer)
Feb 9, 2018
380
748
Carmarthen, UK
Autotrail Tracker
Dec 2017
Afternoon All, hopefully someone out there can help, I'm trying to charge my Huawei phone from my 12v battery (I could charge my previous apple phone with no problems), however it looks like the battery in the phone is being drained although it says its charging, the same thing with my Surface Pro Tablet. I have the MH switched to Aux as it should be, am I doing something wrong? Thanks in advance o_O
Jul 13, 2008
3,743
3,926
Low profile
Have you tried with the phone switched off?
Ginster
Feb 9, 2018
380
748
Carmarthen, UK
Autotrail Tracker
Dec 2017
Yes, it looked like it was charging, but the percentage of charge went down and the tablet didn't register that it was charging at all
43,374
49,757
Sounds like your charger isn't working and a possible short circuit in the charger is draining your battery.
53,693
150,960
What current rating is your charger?
Older chargers often don't have enough to power to charge modern phones.
43,374
49,757
Good point Lenny, but I wouldn't expect it to discharge it.
None of my old 500ma chargers every did, they just didn't have the umph to charge when it should have been a 2amp charger.
Jul 13, 2008
3,743
3,926
Low profile
The Op hasn't said what 12V they are plugged into, I always use high power for tablets and smartphones.
Feb 24, 2013
13,109
101,579
Bolsover, Derbyshire
Hymer S800
not long enough
Have you tried with engine running?
but as above we find we need the high A output on USB type fittings to charge our phones, then they are also quite fussy about the lead, after market leads often let us down
Jan 17, 2014
1,261
2,387
Wellington, Telford, Shropshire
Since 1977
Which Huawei phone?
My p20 Lite charges OK from various 240v plug-in power supplies, various 12v 'Cigarette Lighter' type USB adaptors with 2A type outlets however it does not charge successfully when connected to the USB feed to my original equipment VW Radio. I have the original Huawei to USB cable plus two that I bought off eBay, all work the same.
Having had a camera lead go faulty on me and finding that it is unique to the camera I purchased spare leads for the phone as soon as I had it. Once bitten, twice shy!
Ginster
Feb 9, 2018
380
748
Carmarthen, UK
Autotrail Tracker
Dec 2017
It's not an apple lead They don't fit, and this is the first time charging with 12v, charges OK on hook up, battery getting veryow now so might not respond till I get home tomorrow but thanks all for your responses :D
