How to reset control panel warning
The file should have been a video clip but it won’t allow that to be attached.
However, the middle warning light on the left of the panel flashes and the leds only show one red led when I press the vehicle battery check button. That’s with a 100% charged brand new battery installed.
Sorry, update.
the second light in from the left on the horizontal bank flashes. That’s the vehicle battery one
Second light in from the left on the horizontal bank is the charging light for BOTH. If it is flashing from memory that shows a fuse has blown in one of the two Boite relais securite = Safety relay boxs
Best way to test if fuse has blown is on EHU check with multi meter voltage from leisure battery (should be 12.9 or more perhaps 14.4 charging) if 12.7 or below fuse blown. Do the same from the veh battery whilst connected to EHU
The 5A fuse is a standard blade fuse. The 50A fuse is a Midi fuse, you may need to go to an automotive electrics supplier for these.
Where are the relay boxes likely to be located, near the charger/ leisure battery?
This thread is a blast from my past ::bigsmile:
Ok from previous threads regular viewers will know we have been having ongoing battery problems.
Today we had a new starter battery fitted but the control panel is still showing battery as flat, 1 notch and flashing...any ideas?
6yrs later, today this thread saved my backside. Many thanks to Irnbru and all who contributed. I am "That special kind of genius" who managed to blow the 5amp fuse in the "Bois Relais". I'm so happy I've just renewed my subs!
Your subs payment here will save your bacon and more so a 100 times over. Glad the thread helped someone else.
