How to lock the passenger door with no power (1 Viewer)
F.M.C.Fourier
40
279
Leicester
Swift Bolero 724FB
Since 1987
Hello everyone
I have a Swift on a 2016 Fiat Ducato. I have removed the engine battery to recharge it. Obviously this means no central locking using the key fob. I can lock the driver's door manually using the key, but this does not lock the other cab door and I cannot find any way of locking this. There is no obvious, manual lock on the inside of the cab.
I am guessing that if the passenger door was locked before removing the battery and kept locked whilst the battery was removed, this might be an answer; but this is a very difficult thing to achieve since the battery is positioned under the floor adjacent to the passenger door!!!!
This seems to me to be beyond belief and I am thinking there must be a way to lock the passenger door manually. I have read the manual (which, as always, is as clear as mud), but all efforts are to no avail.
Does anyone know the answer to this, or is it simply the case that No battery = No way to lock the passenger door?
My thanks to anyone who can help.
Graham
Jun 8, 2019
4,931
18,760
Bexley Kent
Given up Motorhoming
May 2019
I have a strap arm rest to arm rest except when driving as others will confirm
F.M.C.Fourier
F.M.C.Fourier
40
279
Leicester
Swift Bolero 724FB
Since 1987
So the door is locked.
Battery is charged.
Battery is returned.
Ohhhhhhh Shiiiiiiiiiiit - how do I fit the battery which needs the passenger door open ?
OK, I'm in a generous mood - jumper leads.
This kind of sarcastic response is unhelpful and not at all friendly. It is also misguided since there is an obvious answer as someone else has already given.
You simply unlock the driver's door with the key, reach across and open the passenger door from inside. Meanwhile my my van is secure from anyone thinking about stealing any of the contents! So I wasn't being stupid at all.
F.M.C.Fourier
F.M.C.Fourier
40
279
Leicester
Swift Bolero 724FB
Since 1987
Thank you to all helpful replies. Problem seems to be solved and very quickly too.
Graham
M-J
Jan 15, 2019
2,663
6,335
Cambridgeshire, UK
Rapido 986F
Getting there!
Little hole in door you can flick the lock with a screwdriver
Edit, Ahhh just seen video posted!
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
No one said you were being stupid, I thought I'd seen a possible real problem in the advice given on YouTube. It looks like I was wrong though I did own a Ford that prevented the interior handles from working when locked so a thief could not do the coat hanger trick.
Riverbankannie
10,632
62,104
Bristol
IH 630 RL PVC
You can set the Ducato locks so they cannot be opened from inside, by double pressing the key,
Oh . . . . or is it single press
Oh gosh now I’ve forgotten! :unsure:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Now you mention it that was how the Ford worked. I did in fact lock my keys in that car once but luckily I'd only single clicked it so I managed the coat hanger trick. I was leaving a factory is Scotland late on Friday and I stood there in disbelief, I had no money, no transport and a very worried look on my face.
Bluemanc100
445
2,459
Hawarden near Chester
Elddis Majestic 155
MH Novice (but a seasoned veteran driver)
Will this help?
It's super easy after watching this video..
My main concern is an insurance claim with my battery removed (mine's been off and charged since the start of the lockdown) because the alarm is inoperative
Maybe mitigated by the fact that my car (a damn Jaguar ePace :giggle:) is next to the MH and therefore the MH can't be towed (or driven) out of the space because of the rear body swing without them stealing the Cub too or damaging both...
Bailey58
8,855
30,040
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
Despite being a member for nine years you obviously haven't become familiar with hilldweller's sense of humour. ;)
TheBig1
17,655
43,515
It just so happens that the lever inside the door is the exact one used by thieves to break into ducatos. a tiny hole by the door handle surround and you have access to the lever that also releases the central locking. achieved using a small sharpened screwdriver which pretty much pushes through the thin outer steel skin. Much the same thickness as a tin of beans etc, so if you want to see how easy it is for yourself, raid the recycling bin and sharpen a small screwdriver
Feb 28, 2023
47
29
Newcastle-under-Lyme, UK
Autotrail Savannah
I'm a relative Newbie
Just used the search bar and up it came complete with video to demonstrate. Think this should have another airing as I'm sure few Ducato Owners know of this. I previously had to remove the battery and found I had to leave the door unlocked and prayed the Secure Park would deter attention.
TheBig1
17,655
43,515
only feels like last week this thread was being discussed. Over 3 years wow
Feb 28, 2023
47
29
Autotrail Savannah
I to was amazed. With the vast amount of MH using the Fiat Ducato base to date, it's the sort of question that one would have thought been asked regularly. Well done the Forum and the search facility.
TheBig1
17,655
43,515
Problem is that too many of us consider some things as common knowledge, but it is a worrying unknown to a new owner
