Disconnect everything, leave it for a while then check the voltage at the terminals using a multimeter. Sometimes the old fashioned way works.
Sunday would work well for me....taxi for 91 yo mother tom!!I’m working bees for most of tomorrow, but we can do a video call on Sunday and I can try to help
It is a good suggestion.I accept this post may not be of immediate help if you have not got such a charger. But, all is not lost if you have a good old fashioned dumb charger from the last millenium. One of those will also get you going again.
Another “easy” way to kick off the charging is to connect a 2nd battery in parallel (even using jumper leads). The charger then sees 12v and kicks in.
However, the massive variation between the Battery Protect and the Shunt has me wondering. Actually solved a similar issue yesterday for someone where it was a simple blown fuse. The solar provided limited power on the one side of the fuse and the BMS reported a different voltage at the battery (on the other side of the blown fuse).
Like you I have suspicions that something in the setup or configuration is wrong. If wired correctly and everything working as designed the Battery Protect should have stopped the discharge.I have messaged Gary and suggested to connect a charger directly on the battery terminals.
The battery protect was not programmed properly, and unfortunately now is on a voltage recovery lock out. Until it hits that value, it will not unlock, by puting a charger on the battery, it may take a charge. As the bms has cut the discharge, it still has voltage on charge port so a charger should see it. If not, as Roger suggested, another battery in parallel. Its all down to the bms if it takes the battery voltage.
My feeling is a victron managed battery and will depend on various system parameters. But, if is a battery with internal bms it will wake up with another battery in parallel.
I also suggested to check the fuses on the sensing wires, the little glass poxy things.
Unplug hookup then check voltage.Sorry for ignorance...where will I find fuses?
This showing battery as OK...I think?
I have resuscitated a inactive battery, bypassing the bms, with the help of a bench power supply. Set CV to 3.2v and current to 1A, as the voltage moves few milivolts up, increase the current to 2A. This is done manually on each cell, till all read 2.8v or 3v. Then re connect the negative bms lead. It will wake up. After that review and correct the bms settings so this does not happen again.Like you I have suspicions that something in the setup or configuration is wrong. If wired correctly and everything working as designed the Battery Protect should have stopped the discharge.
Anyway, again like you I’ve been communicating with Gary over messages, and he’s confirmed that the battery itself is very low voltage so probably US.
The thing with Victron batteries is that if wired or configured incorrectly you may never know it if you never discharge fully. Maybe, just maybe Gary has never allowed the battery to completely discharge and now it’s happened ….
TaH.....thinks I having a romance on the Internet!!!This is why I love Motorhome fun great advice from great funsters
Do i remember you mentioning that those little glass poxy things should be replaced with slightly higher ones but i cant remember what the exact spec was you suggestedI have messaged Gary and suggested to connect a charger directly on the battery terminals.
If it’s a 100ma fitted ( default fitment), change to 1A, even if the fuse is rated to 250v AC , as long as it’s 1A.Do i remember you mentioning that those little glass poxy things should be replaced with slightly higher ones but i cant remember what the exact spec was you suggested
I think you can Ignore the 100% on the smart shunt. It simply has not been synchronised when the battery was actually at 100%. You can synchronise that in settings for the smart shunt when the battery is actually back to 100%
It’s a device that is fitted to the battery negative connection that can measure everything going in and out and therefore tell you exactly what level your battery is at.What’s a shunt? Still learning! Having an extra panel fitted today so starting to dip our toes into better off grid capabilities.
