TOAD on Tour
Thanks for the post, the key feels fine in the lock. It’s actually going next Tuesday to the dealer as they need to fit a new water level gauge for the fresh water tank, so I will also mention it them.When you use the key in the outside of door, does it feel springy?
I had exactly that problem with mine and it was the spring inside the locking mechanism had broken, this does not allow the levers to reset to the correct position.
Real pain to access as the door trim panel has to be removed for access, after finding the problem I was informed by local agent that a new handle lock assembly would be needed only €180 sir, I bought some spring wire of correct diameter and made a replacement.
