How close dare I go towards my Solar Controller's max Voc? (1 Viewer)
Lizbiebrowne
406
492
Teesside
Hymer B654
Since 2019.
Looking to fit a 400 W solar panel to my van and connecting it to my Voltronic MPP 430. The panel has a Voc of 46.7 V and the MPP 430 specifications say the maximum Voc should be 50 V. Is this too close for comfort? There another 400 W panel with a Voc of 37 V and I wonder if it would be more sensible to use this one.
Apr 27, 2016
7,286
8,646
Manchester
A class Hymer
Since the 80s
The panels will have the maximum voltage when the batteries are full and the panels are cold, which is most likely on a winter afternoon. If the panel is flat on the roof (ie not tilted) then the winter sun won't develop the panels full voltage. However I still think it's a bit close to the limit. Best to ask Raul, I think. The controller's maximum voltage is a hard limit, not to be exceeded. Unlike the amps limit, where the controller just wastes power without damage if the amps limit is exceeded.
Dec 2, 2019
3,819
8,304
Amersham
van conversion
Since 2019
At -10C in a morning, with a temp coefficient of 0.3% per deg C your panel will see 53v plus. Look at your panel data, it should give a temperature coefficient. The bigger the coefficient, the larger the voltage swing on cold. The stc data is at 25C.
Dec 2, 2019
3,819
8,304
Amersham
van conversion
Since 2019
The temperature coefficient is negative, -0.27%/ C. Does that change the analysis?
Yes a bit, it will be 51.113v at -10C. So from -8 down you risk burning the controller.
The 46.7voc is at 25C deg.
0.27x 35C= 9.45% 46.7v + 9.45%= 51.113voc at -10C
Apr 27, 2016
7,286
8,646
Manchester
A class Hymer
Since the 80s
It's all relative to the voltage at 25°C. Above 25°C the voltage decreases. Below 25°C the voltage increases. That's because the temperature change from 25°C is negative, the temperature coefficient is negative, so when multiplied that makes a positive voltage change.
L
Lizbiebrowne
406
492
Teesside
Hymer B654
Since 2019.
Thanks Raul and autorouter for the calculations and explanations, I'm glad I asked the question. I will buy the one with the lower Voc: with a Voc of 37.2 C and a temperature coefficient of -0.275%/ C I'm going to have to find some extreme conditions to damage the controller, around -68 C I calculate
