Yes Wissel . I thought the same. Interesting how they build the floor onto the chassis, then install the internal walls and furniture. Then they bond the side walls onto the internals thus creating a structure. There is no frame.Wissel ... might give you some ideas of how you could do your construction.
I have not watched the video yet but all the vans I have seen being built just use a few screws to hold the cupboards etc to the walls, I have certainly never seen any bonded. Some manufacturers build the box and then build the inside while others lay down the floor and build the interior before putting the walls and roof on,Yes Wissel . I thought the same. Interesting how they build the floor onto the chassis, then install the internal walls and furniture. Then they bond the side walls onto the internals thus creating a structure. There is no frame.
The video omits to show how they do that bit though. Maybe top secret.
I have to say it's the most rigid and least creaky/squeaky motorhome I have ever owned. It is absolutely silent on the road. I sometime have to pinch myself that we are moving......well apart from the noisy fiat engine of course
Maybe one day we will go over a bump and all the sides will fall off like that card trick
Informative video, shame about the sound track, instantly jumping from a music track to factory clatter and that God awful blokes voice presenting it.Thanks for that. I have to watch his videos with the sound off, his voice to me is like fingernails on a blackboard to others. Great insight into the factory
interesting t note the largeInformative video, shame about the sound track, instantly jumping from a music track to factory clatter and that God awful blokes voice presenting it.
Wood is the new GRP.Eura Mobil have been building their motorhomes for quite a while now wood free so I was interested to see the large amount of wood (marine ply). At some stage in the life of the van the rot will get into the wood surely.
Is the material resistant to rot or rot free? A difference I believeWood is the new GRP.
New wood based vans use injection treated ply that is resistant to rot for the life of the van. Just look at today's fence posts. They last for ever. Rot has always been it's weakness so if that can be sorted then it's the best material by far. It's even environmentally friendly.....well to a point if you ignore the preservatives.....in that fossel fuels not needed unlike GRP.
It doesn't squeak as much and doesn't expand and contract as much. It's light and strong and has natural insulating properties.
It's still widely used in yacht building although often fibreglass coated.
And most of all it's great for screwing stuff into.
True. Very few materials are truly rot free though are they. Some are just more rot free than others. To be honest I don't know and only time will tell. I know that there are many thousands of vans out there with marine ply floors and most will last a lifetime. It's when manufacturers start economising by using lower grade ply and covering to make it last. That's fine until the covering is breached or damaged. That's when the rot sets in.Is the material resistant to rot or rot free? A difference I believe
Why does he have to shout?Thanks for that. I have to watch his videos with the sound off, his voice to me is like fingernails on a blackboard to others. Great insight into the factory
Foam sandwich with either aluminium or fibreglass facing the outside, certainly not plywood.True. Very few materials are truly rot free though are they. Some are just more rot free than others. To be honest I don't know and only time will tell. I know that there are many thousands of vans out there with marine ply floors and most will last a lifetime. It's when manufacturers start economising by using lower grade ply and covering to make it last. That's fine until the covering is breached or damaged. That's when the rot sets in.
What do the most expensive vans use for floor construction?
To to clarify. There are no leaks.Understanding the construction methodologies, it’s easy to understand why the bloody things leak too!!
That's always a good starting point.To to clarify. There are no leaks.
Medite MDF is guaranteed outside for 50 years, and can be used below ground. I believe most woods can be made effectively rotproof now, although I would have thought cost and weight would be major considerations for MHs.Is the material resistant to rot or rot free? A difference I believe
That's interesting and I think you might be spot on. I woke up this morning and went straight to look under the van. Its definitely some sort of composite material. It feels like plastic but has flecks of wood like particles.Medite MDF is guaranteed outside for 50 years, and can be used below ground. I believe most woods can be made effectively rotproof now, although I would have thought cost and weight would be major considerations for MHs.
I'm now not sure whether it's Medite or Tricoya which has a 50 year outside warranty. I wa going to use it for raised beds nut I lost interest whim I discovered the cost
Mine is only a mid range van, floor is a GRP foam sandwich, inner wall are aluminium no timber in the shell construction.What do the most expensive vans use for floor construction?
I thought on the video at 3.16 he said that was marine ply but doesn't look like it to me, it looks like a moulded part.That's interesting and I think you might be spot on. I woke up this morning and went straight to look under the van. Its definitely some sort of composite material. It feels like plastic but has flecks of wood like particles.
It's not ply of any description.
When is warms up a bit I'll get a photo. Under the garage area it's also a composite material but of different texture . See 3.16 on the video.
I have to say it looks to be extremely well put together and of very high quality.
For just in case you cool Sunlight/ Carado owners havnt already seen this.
I take you are referring to the garage floor, on my Hymer it's a GRP sandwich it looks identical.I thought on the video at 3.16 he said that was marine ply but doesn't look like it to me, it looks like a moulded part.
Thats what it looks like to me Lenny but I thought he said it was marine ply, "look you can see it's been washed" he said.I take you are referring to the garage floor, on my Hymer it's a GRP sandwich it looks identical.
I noticed that and thought what a plonker.Thats what it looks like to me Lenny but I thought he said it was marine ply, "look you can see it's been washed" he said.
