Expandable, Flat or Garden?
What are the pros & cons please?
TIA
TIA
Had our good quality blue food grade flat hose for 9 years now, so failing quickly is not always the case, but as they say, buy cheap, buy twice.I have used flat, expanding and normal types of hose. Only normal last, the others fail quickly.
Phil
A flat pack 20lt bucket is my weapon of choice on a pitch
Any type of garden hose that coils up small.Expandable, Flat or Garden?
TIA
Edit: hose is for home drive use. A flat pack 20lt bucket is my weapon of choice on a pitch
Gonna get one of them , like the fact you don’t need to reel out the full hose to use it.Have a small length of offcut garden hose and a couple of the flat solid hoses that you don’t have to unreel the lot to fill..
Had them a couple of years and they are fine.
ROC Line 15m Flat Hose Reel - Homestead Caravans
Flat hose design taking up less space than standard hose, Hose comes on a reel, ideal for storing away, no tangling | 3 tubes side by side | No need to totally unwindwww.homesteadcaravans.co.uk
I like the look of that. Clever design. Does it accept standard hozelock or equivalent fittings?Have a small length of offcut garden hose and a couple of the flat solid hoses that you don’t have to unreel the lot to fill..
Yes standard fittings.I like the look of that. Clever design. Does it accept standard hozelock or equivalent fittings?
How does it not need to be unwound? It must expand when used?Yes standard fittings.
I have a small length of garden hose to connect onto the end near the tap saves having to unreel that bit.
Another reason we don’t do France. Hate the place.I rather think that most people will struggle to get 100lts of water from a French service point into their van with a 10lt bucket or watering can in the 4 or 5 minutes of time that most give you.
It’s a fairly flat solid hose that has 3 holes running through it, obviously does not fill as fast as a normal hose but it is a good way of filling without unreeling a full hose.How does it not need to be unwound? It must expand when used?
How big is the hose diameter?- Its looks small- does it restrict the flow from the tap?Yes standard fittings.
