Home EHU electricity cost.
Cardiff, UK
Escape 614
5 years
Hi,
For those of you who like to know these things:
Just out of interest I bought a power meter for £10 from Amazon and powered the MH through it whilst in storage on my drive. It's costing the equivalent of around 7p per day, or £26 per year, to keep the batteries charged while they run the electronics, i.e. the tracker, control panel and the base van electronics. It's also handy as an indicator to tell if you have switched everything such as lights and heating off.
More information on the actual power meter please!
Have not worked out how much cost is associated with our van on hook up at home but would like to compare
Hi,
Interesting unless it’s the Darkest time of year our 100w solar panel keeps everything charged and only have to plug in a couple of Days a year for a few hours at a time
No solar panels on mine, I'm under trees and cloudy Cardiff skies!
We're in Pembrokeshire (well we are when we are at home!) and we get enough solar from a 100w panel to trickle change both batteries in the middle of winter. It doesn't take much to keep them topped up each day.
So I have a 150w panel fitted does this mean I don’t have to have electric hook up . Tia.
We also have a 150w panel and don't usually use hook up for 6 weeks in Benidorm. I do switch over for the hairdryer though.
It depends on your daily useage and how much sunlight you get.
Also the size of the leisure battery to store it.
Ours is usually off hookup. but I put a dehumidifier in when we have been away for couple of days, and on and off in the winter months. If left on it doesn't take much out, but having been away it must extract a pint or more of water over a couple of days. Aware of all the arguments about dragging in wet air, but us in an out, breathing moisture, boiling kettles etc, I just like to take that extra precaution. .
if you're not brand infatuated
That's a good way of putting it. It's all too easy to get drawn into brand snobbery when it's not necessary.
Our 240w of solar keep the hab batteries full, but I must admit, the starter battery has suffered since lay up in January due to not plugging in at home.
Same, but squally ‘plug ours in’ a day before we leave to get the fridge cold
I have my van connected to the mains at home through a Meross smart plug. It has an energy monitor function on the app and as I have off-peak electricity for car charging I set it up to come on during the same 5-hour window overnight so I am using cheaper rate electricity and it is not on 24/7.
Living in Scotland I know from bitter experience that my 100w solar panel does not keep the batteries charged through the winter months, I need to plug in for three months.
I have thought about buying one of these meters, just to see what out usage is - trickle charging sports cars and motorhome. To be honest I've also thought about putting a solar panel on the garage roof to provide the trickle charge, might well be one of this summer's projects. For some reason my wife is anti solar panels on the MH.
  • Funny
Reactions: CWH
