Hi OldAgeTravellers i have Fogstar batteries and use the BatMon integration in HA and can pull every bit of info from the batteries including the ability to switch on/off charging on the batteries too, here are a couple of screen shots:dpsuk999 Thanks for this I set up VenusOS on an old Pi-2 quickly to monitor my Lithium Instalation for this holiday but hate the clunky interface and it’s limitations. So am anxious to set up an HA server in the van. My whole house and solar system is running on it at home but as Paul Hibbert says “My virginity is beginning to grow back” with no HA projects to do. I have my pi-3 that used to run the house ( I now use a refurb Wise Thin Client) so you have inspired me to get started on the VAN. If you can share any code I and I am sure many others would be very grateful. I struggle a bit with the coding but have found that ChatGTP is great for getting the basic code down quickly. She often gets it wrong so ask her to check her own code.
Do you have Victron Batteries or does BatMon work with Fogstar?
