toledo
Yes there is still two spaces available
Polly
Polly
I know she said some time, but I lost the will to live looking through the thread to find itWake up Peter she has already said not before 12:00.
The sun will be directly overhead and if your b2b doesnt charge up your new lithium the solars will.I know she said some time, but I lost the will to live looking through the thread to find it
I'll probably be sorting out all the bits he's done wrong.The sun will be directly overhead and if your b2b doesnt charge up your new lithium the solars will.![]()
Let's hope so Jim. How is yours going?The sun will be directly overhead and if your b2b doesnt charge up your new lithium the solars will.![]()
It's working well. Not used my EBL to charge since I finished it all, took out the fuse as you said.I'll probably be sorting out all the bits he's done wrong.![]()
Won't save that much gas as it works in 30 min blocks 2 hours 3 max on a bright sunny day.Let's hope so Jim. How is yours going?
B2B does 30 amps on tickover.
Solar controller seems to be getting more out of the panels than my previous one. 9 amps with light clouds is good for 250W of panels compared with what I was getting. AES works the fridge, so it is going to save me a lot of gas in the summer![]()
My 100ah Ecotree Lithium is doing ok thanks, charging up well with the solar even on duller days.not dropped less than 65% SOC yet.But still have 2 X lead acids as a back up. Just spent 9 days off grid and no issues .Let's hope so Jim. How is yours going?
Been looking for a surface stick on switch to do that. Don't want to drill another 20mm hole as other stuff is in the way.You need to fit a switch or relay in line with AES output from the regulator or the fridge will run on 12v when on EHU, Dometic's dumb firmware.
I fitted a mains relay under the floor, originally I had a switch inside the locker next to the regulator as it's only used occasionally.Been looking for a surface stick on switch to do that. Don't want to drill another 20mm hole as other stuff is in the way.
Nope, a photo would help.Does anyone have a long handled spanner to tighten a small nut on a long screw that is currently not holding my kitchen tap in place?
I've got to say I've tried very hard to carefully chose my wording above - hope I've achieved it! Fingers crossed.![]()
What have you broken now, have you not learned anything from me.Does anyone have a long handled spanner to tighten a small nut on a long screw that is currently not holding my kitchen tap in place?
Sugarnan. Wot they said, and good on them for offering to help out too.You need a 11mm deep socket, a short extension and a ratchet. Mine has come loose in the past. I will be at Hereford, look me up and I will show you what to do.
