Help
Adam b
South queensferry
Auto cruise carrera4
When I started my van for the trip home yesterday the step didn’t retract then I noticed there was no power going to the leisure batteries also the fridge isn’t working on 12 volt ,
Any help appreciated . I have checked all the fuses in the van
Adam b
Adam b
South queensferry
Meant to say it’s puegot van conversion swift
Adam b
Adam b
South queensferry
Batteries are fine I can charge them with the 240 they have just stopped charging while we are driving
& everything else works fine
Weymouth, Dorset, UK
c build
24yr
did you check fuse near leisure battery
suavecarve
Surrey/Hants
Dethleffs Trend A
July 09
Does the step have a button to pull it back in when the engine is off ?
Adam b
Adam b
South queensferry
The step works with the switch, just need to find the cause of these 3 things all going off at the same time
suavecarve
Surrey/Hants
Dethleffs Trend A
July 09
Probability of the relay for the switch which is found somewhere underneath the step. That appears to be working with the engine off so 12 volt supply is ok.
Normally gunk going into the box from underneath and can be cleaned with some wd40.
Whether that issue causes the other issues, I dont know
c build
24yr
can you say what step single or double and mh year might
Adam b
Adam b
South queensferry
It’s a single slide out step on a 2016 swift van conversion, could they all be linked by a relay switch?
Stonemags76
Derbyshire Dales
Auto Sleepers Warwick Duo
Full Time 2011-2013, now part timers!
I might be going mad, but I’m sure I read that the fridge & the step are on the same fuse somewhere?
South Staffs
Pilote P740GJ
Since 2013
I would guess at a relay switch as well.
suavecarve
Surrey/Hants
Dethleffs Trend A
July 09
Youve got my memory banks working now and I think there are some legs in your thoughts
Adam b
Adam b
South queensferry
The 3 things not working are all linked to the D+ signal that may be fused on your Sargent PSU/fuse box (EC460 ?)
The 40 amp fuse at the starter battery positive terminal would also be worth checking
PSU is an ECU400
North West
Florium Wincester
Europe & USA since April '21
When my step and 12v to fridge stopped working, it was one of the red 50amp mega fuses. Which in our van was a group of fuses under the passenger footwell, at the vehicle battery main connections.
Hope this helps.
Adam b
Adam b
South queensferry
Hope this helps.
I had a check of this fuse earlier it looked ok
North West
Florium Wincester
Mine did until I checked continuity with a multi meter and it had blown. The nice red cover looked fine but behind it had melted away.
Adam b
Adam b
South queensferry
I will check again tomorrow thanks
Bracklesham Bay, West Sussex
PVC
There may be another separate orange 40 amp fuse near the starter battery for EC400 supply and fuse 4 (15amp) on the PSU may be worth double checking .
If all fuses are ok it may be a fault with the EC400 which controls (along with many other things) the 3 x items not working and a call to Sargent may be worthwhile 01482 678981
Manchester
A class Hymer
Since the 80s
Starting from basics, are you sure the alternator is working? Does it charge the starter battery? The voltage should rise, from about 12.5V to over 13.5V when the engine starts. Does the red alternator light on the dashboard come on when the ignition is switched on, and go off when the engine is running?
Adam b
Adam b
South queensferry
The stater battery is charging & the alternator light goes out. We had been away for the weekend without hook up & all was well, I plugged the van in when we got home & charged the leisure batteries.
Bedfordshire, UK
RT Pergaso 740
I was thinking the same "D+ signal"
Bedfordshire, UK
RT Pergaso 740
Do the batteries get hot when charged?, feel the sides of them when nearly charged.
Manchester
A class Hymer
Since the 80s
I think so too. The step retraction, fridge 12V power, and leisure battery charging from the alternator are all switched by the D+ (engine running) signal.
The actual D+ signal is working, because the dashboard alternator light goes out when the engine is running. I don't know the details of how the D+ signal gets to the habitation devices. Usually there is a relay switched on by the real D+ signal, which can provide a bit more power, and avoid overloading the alternator D+ signal.
The supply to that relay will have a fuse, usually 2A or 5A. It might be located near the starter battery or in the distribution box.
London
Elddis 185
since 2010
There was a post recently about the step not retracting when the engine started maybe a Ducato or Peugeot. The problem was the relay which is situated in the (d?) frame upright which is on the right hand side just beside /behind the drivers seat. Check everything else as mentioned above as it’s quite fiddly getting to the relay.
PVC
Adam b The fuse F49 (5amp) in the cab dash fuse/ relay box appears to be linked to D+ function . (on a Fiat X290 cab but Peugeot should be the same)
