Brakers
Hi There yes i'd heard that as well as the 8yr change, it's a bit confusing isn't it.I thought tyres should be replaced after 5 to 6 years
They’ll still pass the MOT so long as there are no obvious signs of severe cracking. The number of years old advice is variable because there is so much that can affect the life of a tyre. Continental told me to pay particular attention to the tyres after 5 or 6 years but don’t go over 10 years old regardless of how they look.I have an headache LOL, my MOT is next week I think i'll wait and see what they say.
They did last year inform me of the age of the tyres but it still passed the MOT then so I'll see what they say.
Best Wishes Tony
Depends on the time of year you intend on travelling. Where I live which is about 500 miles south of the uk , our normal winter is like the worst uk winterWould you need winter tyres going south from the UK..
But would the OP be travelling via the Rhone Alps or via the western route in France or even Portsmouth to Santander/Bilbao.Depends on the time of year you intend on travelling. Where I live which is about 500 miles south of the uk , our normal winter is like the worst uk winter
Nope...the rating is the same as Agilis Camper....so the manager at Quick fit advised...Are these load rated for motorhomes as I thought the load rating was for light commercial van on these tyres ?
We get quite hard winters here in the Limousin also.
They were acceptable in dry conditions but horrendous in damp or in the wet.
Bit like Bridgestones when they were first available on Jap bikes in the 70's.
Tyre age is not an MOT testable item.My MOT tester said "you're tyres are in good order BUT they are 10y old: I suggest you change them".
He passed the vehicle.
The Massif Centrale in the middle of France (A75 etc) can be closed for hours (or days in severe weather) due to snow.... Then there's the pyrenees mountains into Spain.Would you need winter tyres going south from the UK..
On the subject of tyres regarding long periods of parking , apart from taking short drives to get the wheels on a different flat spot , would keeping the tyres closer to their max pressure thus keeping the flat part to a minimum help with longevity ?
I am in the process of looking for tyres, I am running on Conti Camping tyres and am very happy with them. But the added choice of the winter tyres causes confusion especially as Conti now classify the campers as summer tyres. Plus I have found that none of the large fitters have the 4season-2 available nor are they interested in getting them. Just one supplier would order them but at £200 each. I am only in the UK for one more week and my existing tyres are only half worn but 6 years old although the walls inside and out show no distress at all so I asked Conti and this is what I received back which may be of interest to some.
As I have so little time I will have to unfortunately source them in France now.Tyre ageing is a chemical and physical process that occurs slowly over time. It can affect tyres very differently depending on tyre design, age, maintenance and application. This is because the tyre is a very complex piece of equipment and has many factors which affect its lifespan which I’m sure you can appreciate.
Continental would recommend any tyre that is more than ten years old to be removed from service due to this aging process. However, there is no UK law stating this and you can have any age tyre fitted to your vehicle/ trailer.
The main reasons for the Camping Industry recommendations are mainly due to the conditions which most vehicles/ trailers in the leisure industry are used. With often high loads, which are usually uneven, prolonged periods of static use (either on or off the vehicle) and the fact most tyres are left outside to face the elements, these factors combined can exacerbate the ageing process. This gives a clearer reason as to why tyres are recommended to be removed 5 years from the manufacturing date but this is only a recommendation. Of course, the coach builder or manufacturer may have already stated a tyre fitment guideline and if so we always advise following this. Also some insurance companies also have a recommended tyre fitment policy so it is always advised to confirm this with them directly.
Has anybody out there switched from the Conti Campers to the Higher load rating 4Season-2's? I like the Campers because of the wall stiffness and am a bit wary of changing, my last van had Michelin Campers and I like the Conti ones better, I do run constantly at maximum weight on the rear; 2,400kg so the 118 or 121 rating would be good. My wheels are 225/75 R 16. on a Hymer Ducato Euro 5.
But it is a very confusing situation, to me at least.
