- Aug 29, 2010
- 888
- 1,376
- Hymer Exsis t564
- Since Sept 2010
Measure them silly boy, from memory I think they are M5.BTW, what size are the bolts for the tap tops
And why would I know how to do that? I was an underwriter not an engineerMeasure them silly boy, from memory I think they are M5.
Thanks for that. I have decided to convert my system to pressure activated so, hopefully, I will not be replacing the faulty microswitch. Just got fed up when both the toilet basin and kitchen sink taps failed in the 3 weeks we were away. Rigged up a switch system as a temporary fix and will be changing the system in July when we have some time at home.peterc10 Don't know what number it is, but Graham thinks he's got the right screwdriver. (He hasn't been able to get the screw out with it though, due to corrosion .)
He'll have it in the van at Ashbourne and Bedale, if you still need to use one, be our guest !
Well I have now fitted a whale pressure switch, so my system is now pressure activated with no need to rely upon the crappy designed microswitches. Once I had assembled all the stuff I needed it only took about an hour to fit it all. Still using the quiet submersible Reich pump just changed the way that it switched on. And when that pump fails I already have a spare waiting. Slight clicking on the pressure switch but only lasts for a second or two.Thanks for that. I have decided to convert my system to pressure activated so, hopefully, I will not be replacing the faulty microswitch. Just got fed up when both the toilet basin and kitchen sink taps failed in the 3 weeks we were away. Rigged up a switch system as a temporary fix and will be changing the system in July when we have some time at home.
See you at Ashbourne.
That is OK but the micro switch was £18 and a new tap was over £100.Just love the lengths some will go to fix things ,in this case the tap micro switch as I’ve posted elsewhere I just replaced the bloody tap !!
happy days
If I had done that it would have cost me well north of £300 in the last few years. That is for two basin taps and one sink tap. And it would still have been a real struggle to do it because of the awkward access. Those 3 failures have also caused real hassle as they always happen when we are away enjoying ourselves, so limited tools and patience available!Just love the lengths some will go to fix things ,in this case the tap micro switch as I’ve posted elsewhere I just replaced the bloody tap !!
happy days
Or just fit a switch on the system. Flick the switch pump runs.Just love the lengths some will go to fix things ,in this case the tap micro switch as I’ve posted elsewhere I just replaced the bloody tap !!
happy days
peterc10 Does the conversion to a pressurised system place any strain on the plumbing joints ?
Tried that as a temporary solution drove me nuts.Or just fit a switch on the system. Flick the switch pump runs.
We had that temporarily when the microswitch went and it drove us round the bend. Trouble is when you forget to switch it off and the pump burns out. Forever having to remind each other. And it would be very inconvenient for showering.Or just fit a switch on the system. Flick the switch pump runs.
Only time will tell. So far no sign of leaks, but we will soon find out if there are. It will cause the pressure to drop so the pump will start up without us switching on the tap.peterc10 Does the conversion to a pressurised system place any strain on the plumbing joints ?
Only thinking temporarily. Had to do it to mates caravan on Sunday.We had that temporarily
