FARO Type Ø6mm Poly Pipe - 1 meter
Poly Pipe 6mm used for autogas, LPG conversions produced by FARO Type
www.lpgshop.co.uk
Don’t worry as you are probably well aware the diy experts always know far more than anyone elseworries me, the op asking all these questions. Should you really be doing this rather than someone more qualified?
Exactly as I said before it will probably do the job but why when you know it’s not approved, just means a dealer or new owner that has it inspected has to rip it out and do it properly.No I shouldn't, but trying to find a LPG qualified gas engineer around here who would fit a BBQ point for a reasonable cost has proved impossible, even though we are surrounded by marinas, although that might just mean they have plenty of easier work. Manufactures have no need of Faro pipe since they install gas pipe at an early stage of construction. I'm certain that Faro pipe correctly installed with the rubber lined securing clips and avoiding possible abrasions points is perfectly safe. Not being approved for an application means just that, it doesn't necessarily mean it's not suitable.
So trueDon’t worry as you are probably well aware the diy experts always know far more than anyone else
Funny the Dyers always say that too ,and it’s never them that have touched the gas and got PTFE tape wrapped around anything in sight ⚠So true
When the gasboard guy was changing the regulator on my gas meter he asked if I did my own plumbing, yep I replied. He said a lot better than most of the work I see by professionals.
Never heard of 'maladgerated' and it doesn't come up in a google search ... is it a specific 'gasman' term?Dealers fixed a customers leak the other day ⚠
PTFE and some sticky sealant on the compression joint to regulator ⚠
secondhand van 14 plate so still a few quids worth ⚠
Fitted him a newCavagna regulator for £20 cut pipe as it was maladgerated , hence why it was leaking .
Not just these days. Just after I bought our bungalow I had some loft electrical work I wanted to do. The gas pipe came from the garage loft (the meter was in the garage) to the house loft via 22m copper laid on the rafters. It was around 15ft long then split using a T to 15mm to the living room and kitchen. The T was a capillary fitting. I lifted the gas pipe about 3" in the middle of the run to release a trapped mains cable and .............. the T fell off the end of the 22mm pipe. I had to put my thumb over the end until wife had unlocked the garage and turned off the gas. Examination showed that the T to 22 joint had never been soldered. It had been like that for at least 20 years.Some of the worst work you’ll ever see is actually British Gas these days ⚠
We’ve found a few like that it’s amazing how they actually don’t leak until you disturb themNot just these days. Just after I bought our bungalow I had some loft electrical work I wanted to do. The gas pipe came from the garage loft (the meter was in the garage) to the house loft via 22m copper laid on the rafters. It was around 15ft long then split using a T to 15mm to the living room and kitchen. The T was a capillary fitting. I lifted the gas pipe about 3" in the middle of the run to release a trapped mains cable and .............. the T fell off the end of the 22mm pipe. I had to put my thumb over the end until wife had unlocked the garage and turned off the gas. Examination showed that the T to 22 joint had never been soldered. It had been like that for at least 20 years.
Good stuff fluxWe’ve found a few like that it’s amazing how they actually don’t leak until you disturb them ⚠
More of a polite way of saying what has really been doneNever heard of 'maladgerated' and it doesn't come up in a google search ... is it a specific 'gasman' term?
