I could really do with some advice on what to do with my motorhome as I'm at the depressing point of just seeing it turning more and more towards a scrap item if I don't do something to stop the issue.
I know there will prob be damage internally as I don't know how long this water has been getting in, but I have a couple of external damaged areas I've found, and water has clearly been getting in, as internal wall board is slightly soft although no damp patches as such.
I just need to work out what I can do to stop any more getting in and deal with any internal structure issues once I know it's sorted, but I'm not sure the best course of action.
First is the hab door.....
Above the door is soft on the wall board where someone has badly installed an external light
I thought I just needed to deal with the holes left by that, but it looks I may have an issue with the fit of the door frame itself.
The side of the mh has a slight bulge for some reason at top right of door and I think this may be where water is still getting in. It's a plastic style body not sure on the material, but it's not the aluminium skins you see on some.
I don't know if I should remove the door to refit, or just run some kind of sealant round it. There is a load of old mastic around it though and I'm not sure if sealent will adhere or react or if it's even a good idea....
Pictures attached of where bulge is and where soft internally.
Is there anywhere northwest that deals with this sort of stuff that anyone would recommend speaking to? She's an old girl... 99 bessacar e695.
Any advice really appreciated. Please don't just say it's scrap or you've bought a nail.....I already know this but I need to now try and keep this thing going as long as poss. I can't afford to just chuck many thousands of pounds down the drain..... Although it's kind of feeling a little like I've done this.
