Help needed Morrisons Falkirk
Basildog
It’s a long shot but does anyone have a Gaslow Spanish adaptor with the non return valve in it ?
A van owner is stuck leaking LPG from the filler point due to a missing cap that has allowed dirt into the filler point due.
My number is 07549 811501 if anyone locally can help ?
Sorry I can't help with the adaptor but can he not clear the dirt by poking a Bic biro or similar into the valve to blow it out ... it worked for us with the same problem.
There should also be a non return valve at the bottle or tank end so it will only be the gas in the pipe between the filler and the tank. I appreciate its a leak but hopefully that’s all it should be
Unfortunately once dirt is in the filling system it very often causes both non return valves to stay open ⚠️
Hence (Hopefully)
I am heading up to Scotland today if they are still stuck?
Heading to Bridge of Orchy though. :-(
All sorted now thanks, the forecourt’s operators called in their LPG engineers to cap it off .
They wouldn’t allow the owner to disconnect from the pump until they arrived .
Thankfully we don’t see many of these incidents happening but it’s why I can’t stress enough the importance for making sure that a cap is always present on the filler point.
