You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
Help needed I have just bought this rohill conversion and the air rod will not rise the compressor is working but it won’t rise any ideas would fantas
(15 Viewers)
I think he means it won't lift the body off the ground to enable him to drive it.
Air rod must be Some piston device to lift the body.
Op needs to follow compressor lines to see if there are any valves that need opening/ closing. IMO.any gauges evident.??
