And the only thing behind that would be a dropped spanner!That appears to be the starter motor¿
If he could tell us where he is as you say there must be one of us nearWhere are you located ? I live in france and can offer a workshop and pit for you to work in if nearby I am 30km south of Bergerac. Secure parking etc no cost to help a fellow..
He has..If he could tell us where he is as you say there must be one of us near
He is in the Massif Central, he posted a map in post #18If he could tell us where he is as you say there must be one of us near
He is a fair bit from us :-( We had a similar problem with our 1999 Fiat so will get back to youHe is in the Massif Central, he posted a map in post #18
Edit:
I'm not as fast a Gary.![]()
It's a 1995 but that pipe is far too small for an intercooler... Looks about 15mm to 20mm internal. I would expect at least 50mmIf it’s around a 1973 Fiat it may well have a turbo, the cooler is on the nearside of the radiator it looks like the pipe from the inter cooler to the intake manifold.
spitfire thanks so much for the offer. With relations with my better half getting too strained we are now on the back of a depannage. It's actually lovely to be able really enjoy the scenery - oh the passenger's life!!!
Some one will hopefully be attaching the breather tomorrow, I am sure for an extortionate sum. Thankfully our RAC cover is paying for the tow.
Would any French/French-speakjng FUNsters be able to tell me in French what we collectively think the problem/resolution is?
Thanks again so much everyone. The fun is a really special community to be a part of.
Seems to be lots of jubilee clips on the various hoses in the photos, sometimes not the best clips to use, but as the loose open hose has a jubilee clip still attached it looks as though its just popped off. Can't be that difficult to put it back to the correct location, when it's viewed on a garage rampA half decent mechanic should have that hose sorted in 1/2hour or less so dont let them get one over on you . What caused it to blow off is more of a concern . as it may be down to engine wear causing excess blow by !
Have sent in a messageAC/DC that is an incredibly kind offer. Hopefully by tomorrow afternoon we'll be on our way again, but I'll keep that in mind. Thank you.
Jimbohorlicks yep, fingers crossed. Out of interest what's better to use? All the jubilees were present when I purchased the van but maybe I can slowly replace...
dunnah01 thanks - I will try to get that across in my best French...!
spitfire thank you - maybe if you could send that to me that'd be handy (just in case!) - thank you!
If you are having a problem understanding the French perhaps a call out to yodeli could help. Frankie has helped a number of stranded funsters in the past she is hailed as a star.Thankfully WJACC to a VW garage where we can spend the night and they will look at it tomorrow - from what I can establish in my broken French!
It might if it’s dumped all the oil and the op in their own words said they are not mechanicalSeems to be coming out of the crankcase, so probably breather hose, as noted above, start engine & put hand over it, if it blows air and a mist of oil, it is a breather hose. Why it blew off could be the ambient temp plus age or something much more serious, such as dropped a piston ring, you would know if a piston was holed as it would be only running on 3 cyls. Motor having no go is worrying cos a breather hose off should not affect performance.
