- Feb 22, 2011
- 11,224
- 24,254
- Hymer B544 A Class
- Since 2015
This thread is more entertaining than strictly
PS hope you get your batteries sorted soon
Every vehicle, including a motorhome, has an alternator that produces electrical power when the engine is running, and charges the starter battery. In a motorhome, the leisure battery connects to the starter battery when the engine is running, and the alternator charges both batteries at the same time.Before I go on and on can you tell me something. If the engine is running.. (I have an engine, 2 leisure batteries quite new, 2 solar panels, a battery master)......... and a garage man puts a multimeter or whatever it's called on the engine b, and checks and says if battery receiving powerand says, therefore, 'No. You don't need a new engine battery, it' s good and receiving power. And I say, 'Yes. But it' s receiving power from leisure battery I think cos panel indicator flashing that leisure batteries are GIVING OUT 6.3 V.! '
He says,' Oh, I know nothing about leisure batteries. '
THANK YOU.That would show on the panel indicator as amps going out of the leisure battery. But it would be Amps not Volts going out of the leisure battery.
An autoelectrician who didn't know about leisure batteries might mistake power from the leisure batteries for power from the alternator. It's easy to tell which is which. For example, if he pulled the leisure battery main fuse, to cut off the leisure battery, then he could tell from the starter battery voltage whether the alternator was working or not.
I dont get that statement.. the joining of the two battery banks is dependant on a signal..if the alternator isn't working there will be no signal and no joining of the two banks..If the alternator isn't working, when the engine is running the leisure battery still connects to the starter battery.
If it has totally failed, you are right, there'll be no D+ signal so the split charge relay won't trigger. However there could easily be other faults where it doesn't produce enough to charge the batteries, but the D+ signal is still active. I'm no expert on alternators, that's only my guess.I dont get that statement.. the joining of the two battery banks is dependant on a signal..if the alternator isn't working there will be no signal and no joining of the two banks..
Or am I missing a point somewhere..??
Andy
It wouldnt try for long..... 300 amps starter current through a 1 or 2mmsq wire and the wire itself would melt in seconds, if that long.Think your leisure battery is trying to start your engine and its not built for fast output to starter motor.
A lot of posters seem to have missed this.Before I go on and on can you tell me something. If the engine is running.. (I have an engine, 2 leisure batteries quite new, 2 solar panels, a battery master)
That's the difference between the ignition signal and the D+ signal. If the split charge relay is triggered by the D+, it doesn't turn on until the engine is running and the starter motor has stopped, and by that time the alternator has powered up enough to send charge into both batteries.When the engine starts cranking the starter battery voltage will go down to say 11.5v. BUT the leisure battery voltage does NOT drop ! If the leisure battery was somehow was wired to supply voltage to "top up" the starter battery I would have expected to see it happen then.
Battery master only trickle charges the engine battery at 2amps when the engine battery drops a set amount below the leisure battery. It neither can or could carry the starter amperage.A lot of posters seem to have missed this.
No. Joy didn't say that.Maybe I'm am reading it wrong, but did not Joy say that there was a current of 6.3A from the leisure battery into the starter battery ?
If so, what conditions of engine starting / running / not running would cause that to happen ?
I was trying to imagine what could cause a 6.3A current from the leisure battery to the starter battery, while the engine was running, which is what the OP described. I thought that if the alternator failed to produce charge, but still sent out the D+ signal to trigger the split charge relay and connect the two batteries, then charge might flow from a fully charged leisure battery to a partly discharged starter battery.Maybe I'm am reading it wrong, but did not Joy say that there was a current of 6.3A from the leisure battery into the starter battery ?
Should you not see an ignition warning light as well?I was trying to imagine what could cause a 6.3A current from the leisure battery to the starter battery, while the engine was running, which is what the OP described. I thought that if the alternator failed to produce charge, but still sent out the D+ signal to trigger the split charge relay and connect the two batteries, then charge might flow from a fully charged leisure battery to a partly discharged starter battery.
I agree that the Battery Master cannot supply the current required to start the vehicle. However in an earlier post Joy said that the mechanic measured the cab battery at 13.1 v(ithink that was the value) could that have been the voltage being suypplied from the leisure battery via the battery master without any current being drawn.Battery master only trickle charges the engine battery at 2amps when the engine battery drops a set amount below the leisure battery. It neither can or could carry the starter amperage.
A B2B charger is one way only... Engine to leisure.
I think she is Somerset area, Movan, where are youmovan. If you don't tell us where you are Joy, none of us willing to assist you are able to.
What you are experiencing is not difficult to solve, but not knowing where you are, makes it very difficult for those willing, to help you out.
It doesn't need to be an exact location, ie, a rough location will do for folks to know if they are within helping distance.
Cheers,
Jock.![]()
on another thread jockaneezer was saying if you run cab bateery down and then turn oin ignition it suckes from the leisures which suggest the split charge is ignition rather than d plur operatedmovan. Are you anywhere near Peterborough Joy? If so, send me a PM please, and I'll return with our contact and location details.
If your engine started, then the cab battery must have enough power, and like Spriddler, I would suspect a bad connection or earth to be the cause of intermittent starting.
Re the leisure batteries powering the cab battery? No. Once the cab battery reaches a certain voltage from the alternator, the split charge relay kicks in and sends that same charge to the leisure batteries, not the other way round.
If no solar power, and not on EHU, there is every chance your leisure batteries may be very low, but if as low as 6.2v................that means they will be kaput.
Jock.
My paperwork shows Battery Master connected. I thought it said by VanBitz?i doubt joy has a battery master as its the same van as ours and charges both batteries via the ebox
That is what I think is my first choice. . I wish I had been confident enough to argue that point with the first garage guy... It's just that I KNOW I havn't an indepth clue so lacked standing up to him.i think youve got a flat engine battery get some one to disconnet the earth lead to the leisures and get it tested again thats if it will start without the leisures
My link through the split relay is starter almost sizeIt wouldnt try for long..... 300 amps starter current through a 1 or 2mmsq wire and the wire itself would melt in seconds, if that long.
