Learn to use the search facility.
To help, look for "Truma iNet Ready upgrade? Is it easy?".
Are you sure it was the CPlus that was falling over and not you 'cause you was sozzled!I fitted a CPlus to our last van it kept falling over when the timer was set, a software update cured it. No problems with the current van (2017).
Might be worth having a look at:
If you find out how to get the system to control the heating temp +- 0.5'C let me know
Agree re vid, but posted with the view the OP does a bit of research on utube to answer some of there Qs.Mine works very well on temperature control I think it depends on how good the installation is, also have you set up the offset to suit your van.
That video give you the basics but fails to tell you how useless the ECO setting is & that the boost turns off the heating while heating the water. Also didn't explain with the fan on ECO it is really an auto setting where the fan speed automatically adjusts where as in HIGH it just runs flat out.
Also no mention of the OFFSET or Timer.
The hysteresis is only relavant to the ECO hot water setting.Agree re vid, but posted with the view the OP does a bit of research on utube to answer some of there Qs.
Vis our new MH with inet very different from our older kontiki 679.
Going to get the dealer to recheck the system as unless on gas or a 4'c differential between set point and process variable on mix it doesnt do much.
System hysferisis seems to be excessive. Looks to work better on gas than electric or mix.
Yes have tried setting offset but hysferisis or lack of fan speed on Eco is the issue.
Unless someone knows a fix
AahhThe hysteresis is only relavant to the ECO hot water setting.
My heating on ECO fan speed stays on full blast until van is up to temp then gradually slows down to a wimper can't even hear it but keeps the van temp very stable.
A lot does depend on the install, we have 4 vents in the cab area and vents on top of the dash in front of the screen & one by the hab door. Rear end has one central vent, vent in shower & the washroom and vents all along the side of each bed and all the ducting is in the double floor keeping the floor warm.
Would further add that Hysteresis is the differential between switch on and switch off. where say the heating has a set point of 21'C and switches off at 22'C but doesn't turn back on till temp falls to 20'C. +/- 1'C. So the differential of 2'C feels quite a lot to the human body, expect home heating thermostat to work within +/- 0.5'CThe hysteresis is only relavant to the ECO hot water setting.
