- Sep 7, 2024
- 20
- 54
- Campervan
- Vauxhall Movano bus
Hello how do you guys heat the campervan when there is no electricity available to use are you are not on a campsite
Same here IF my Eberspacher diesel heater fully worked!![]()
I have been thinking about it!Maybe time to swap over to a more reliable Chinese diesel heater like we have.![]()
Same truma system on gas setting. Be warned if it's very cold it uses tons of gas, as in a 6kg bottle in 3-4 days. You ideally want refillable canisters if you plan to be offgrid for any period of time as 2x11kg will likely last a couple of weeks.Hello how do you guys heat the campervan when there is no electricity available to use are you are not on a campsite
Built in Truma gas blown heating.Hello how do you guys heat the campervan when there is no electricity available to use are you are not on a campsite
Not much difference in the cost of running gas or diesel. Refillable propane gas at £1.00 per litre giving 7.08kWh of heat costs 14.1p/kWh. Road diesel at £1.38 per litre giving 10kWh of heat costs 13.8p/kWh. Red diesel would be cheaper but you would need a separate tank.The gas heaters use far too much gas!
Where do you buy Kerosene ?Use a diesel heater in my house garage always run it on kerosene they run cleaner and don't carbon up as much on kerosene.
Do you syphon some from the Lear Jet ?
Kerosene is home heating oil, which is what I use in our diesel heater.
Rye Oils in Rye East Sussex, they wil ship 20lt but expensive at £31.50.Where do you buy Kerosene ?
I put a 20 Lt container in the van and fill up at the pump there. Mi's brother & mum live in Lydd so we are often passing them.
Yes it is, find a friend with a heating oil tank, and syphon out few liters and give him some beer money, its 55-60 pence per litre.That's more expensive than normal diesel isn't it?![]()
Yes but that's in containers and shipped, I buy it at the pump I don't know current price but never paid more then 95p Lt has been down in the 60's.That's more expensive than normal diesel isn't it?![]()
There's also the diesel pump which is extra draw compared to gas that's fed to the burner by its own pressure.Only for a few seconds on start up for the glow plug, overall probably not much in it.
