Couple of things:Here’s my homemade Fogstar bought batteries. I made these around April 2023. I made two 280amp approx batteries, I was making one 560amp but the JK bms didn’t allow each cell to be monitored separately and it was bloody heavy. So I made two with two BMS’s. Glad I did as one bms did fail in the first year while camping and fortunately that meant I had one working battery left!
The cells were B grade eve of which I didn’t balance as they were all pretty even already. The only so called special tools I used was a cable crimper and volt meter. I made my own flexable busbars from 28mm copper tube as there were non available at the time and two boxes from ply. I added a sponge type foam tape to the cells and the boxs to allow expansion and separation also 20mm insulation at the ends.
Cost at that time was about £900 I think.
These batteries do not like the cold so bear in mind if they do get cold you can’t charge them, you can still use what’s left in them but that’s it until they are warmed up.
If I were making them now I would buy A grade cells although ours have been fine but the cost difference is really not worth it.
Why didn't you go with the nickel plated copper bars? They are better against the aluminium terminals, compared to the bare copper.
Secondly, why no cell separator/insulator between the cells? That shrink wrap is not enough, needs additional electrical insulation.
Also, bms on top of the cells open terminals without insulation is a no no, a separate compartment on the side will be better as the bms produces heat, and those middle cells will get enough heat from neighbouring cells as it is.
Just my thoughts.
